RC Scale Boating Enjoy rc scale boating? Talk about it here.
Scratch built Polish Tug "Klimek"
Reply
Old 08-14-2013, 08:14 PM
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've come up with a couple of options so far.
Half round balsa. Which would have to be glassed.
Half round from Plastruct. Which is kind of short at 14", would have to piece it to together.
Hard wood dowel cut in half on band saw.
wayne d is offline
Old 08-16-2013, 01:43 PM
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made a little progress today. All the parts and wood came in.
So I started work on the wheelhouse.
Once it was all rough sanded I started to fit it to the hull.
I started looking at the arrangement and may end up gluing the wheelhouse on and have the engine room and smoke stack cover the only part that comes off. This will help with water intrusion.
ID:	1909170   Click image for larger version
ID:	1909171   Click image for larger version
ID:	1909172   Click image for larger version
ID:	1909176   Click image for larger version
ID:	1909177   Click image for larger version
wayne d is offline
Old 08-16-2013, 01:45 PM
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Of course the rear deck will have to be removable to access the motor, and steering arm.
wayne d is offline
Old 08-18-2013, 08:50 AM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Wayne. Keep on keeping on.
rblubaugh is offline
Old 08-20-2013, 12:48 PM
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a little progress.
I have also decided to have the entire wheelhouse removable.
For normal operations the engine room top will be held on with magnets and this is where I'll install the switches. Pop it off, turn it on, pop it off, turn it off. Easy.
For service to the motor, coupler, servo and esc the entire wheelhouse can be removed with a couple of screws.
ID:	1910780   Click image for larger version
ID:	1910781   Click image for larger version
wayne d is offline
Old 08-20-2013, 01:06 PM
  #31
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wayne,
You really like thise earth magnets. They obviously work well for you.
Bob
Old 08-20-2013, 01:10 PM
  #32
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I do, they are super strong.
wayne d is offline
Old 08-20-2013, 04:44 PM
  #33
blizard05
blizard05's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The boat bug bit you big time,like they say "you can't just build one" looking good Larry
blizard05 is offline
Old 08-20-2013, 04:47 PM
  #34
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You got it correct Larry. I've pretty muched stopped fly altogether in about the last year. Pretty much all boats now with my daughter.
wayne d is offline
Old 08-20-2013, 05:38 PM
  #35
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a little bit done this evening.
Sanded stuffing box to promote a good bond and glued it in using Hysol. I'll let that sit overnight and work on mounting the motor.
ID:	1910953   Click image for larger version
ID:	1910954   Click image for larger version
wayne d is offline
Old 08-21-2013, 03:38 AM
  #36
blizard05
blizard05's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you going to use a reduction gear in the drive line ? You could swing a bigger prop by using one. I am using one in the ORCA Larry
Old 08-21-2013, 03:44 AM
  #37
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The picture is kind of an illusion. I should maybe only go a 1/4 bigger on the prop.
right now, direct drive.
wayne d is offline
Old 08-21-2013, 11:46 AM
  #38
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was able to swap the motor mounting plate around to give me access to the mounting screws. I then cut a 1/4" ply plate to fit in between the stringers. Once the Hysol is dry I'll put the other two screws in place and the motor is done.
ID:	1911214   Click image for larger version
ID:	1911215   Click image for larger version
wayne d is offline
Old 08-21-2013, 04:11 PM
  #39
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This plate will hold the servo.
And this plate will hold the ESC
ID:	1911301   Click image for larger version
wayne d is offline
Old 08-21-2013, 04:17 PM
  #40
Tidnab
My Feedback: (51)
Tidnab's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This place might have what you're looking for. http://www.cowlesproducts.com/protekto_wheel.html
Tidnab is offline
Old 08-21-2013, 04:21 PM
  #41
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That might work, I'll take a look around and see if I can find some locally. Thanks for the info.
wayne d is offline
Old 08-21-2013, 06:17 PM
  #42
Tidnab
My Feedback: (51)
Tidnab's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you can't find it localy ,Ebay has it . http://www.ebay.com/sch/i.html?_saca...und+trim&rt=nc
Tidnab is offline
Old 08-21-2013, 10:36 PM
  #43
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anybody have any idea if the Mtronics 25a ESC will be ok for the motor I have?
wayne d is offline
Old 08-21-2013, 10:43 PM
  #44
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
800 Direct Drive Motor from MFA Como Drills
Top RPM: 5167
Runs on 12 Volts
3 Pole
Maximum amperage draw: 5.28amps
Will efectively propel a 36" deep vee boat with a 2" prop Can also turn props up to 3.5 " @ 2500 RPM
Motor mount included.
Overall Length: 4 1/4"
Can Length: 3"
Can Diameter: 2"
Drive Shaft Diameter: 1/4"
Drive Shaft Length: 1/2"
wayne d is offline
Old 08-22-2013, 07:15 AM
  #45
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wayne,
Here's some other trim, wood, on ebay.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Bob
Old 08-22-2013, 07:20 AM
  #46
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wayne,
From what you describe about your motor the ESC should be fine. If you want to protect the ESC, put a 20A or 25A auto fuse in the positive leg of the ESC. If you exceed that amperage the fuse will blow instead of your ESC.
Bob
Old 08-22-2013, 10:24 AM
  #47
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, that's the one ill plan on buying.
wayne d is offline
Old 08-22-2013, 12:16 PM
  #48
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by rblubaugh View Post
Wayne,
Bob
Thanks Bob
I keep forgetting about the dollhouse stuff.
wayne d is offline
Old 08-22-2013, 12:55 PM
  #49
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anchor pocket thingy done.
Almost.
ID:	1911638   Click image for larger version
ID:	1911639   Click image for larger version
wayne d is offline
Old 08-22-2013, 02:07 PM
  #50
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gotta put the anchor someplace.
