Dumas Chris Craft - Butterfly Keel????
Howdy,
My wife decided she wanted to try building a boat, and she fell in love with the Dumas Chris Craft Runabout. I have built boats before (fiberglass race boats and plastic electrics) but never a wooden one like this, so I am of limited help. What is a Butterfly Keel? We cant find anything in the manual or plans to illustrate what it looks like, or where it goes. Can somebody please help?
Thanks!
Ron
Thanks!
Ron
RE: Dumas Chris Craft - Butterfly Keel????
We can get you lots of help on the wood construction, but I
can only imagine what a "butterfly keel" might be...[]
It doesn't even seem to Google...[:@]
from what i understand its a method of biulding hulls try this it may help
http://www.bandbyachtdesigns.com/cs20.htm
Ok, I got your Butterfly keel here.
on most keels you have a vertical piece of lumber that the frames sit on.
Dumas use two 1/8" pieces laid flat rather than on edge to form the stern of their boats.
Here is Pat Tritle's Description
You can see that section on this build up. Post Number 4
http://www.rcgroups.com/forums/showthread.php?t=215695
The "butterfly keel" is the type of arrangement that Dumas likes to use on the rear hull section of their boats. The typical keel is a verticle member onto which the frames are attached. The butterfly keel lays flat with the bottom of the frames. Dumas uses 2 pieces of 1/8 X 3/4 bass wood for theirs, so the keel ends up 1/8 thick X 1 1/2" wide. The advantage is that there is a wider gluing surface for the lower skins, and insures a much straighter hull. There is also a substantial amount of material to pass the stuffing box through.
I just wanted to say "thanks" for the help! My wife revisted the kit after reviewing the info here and we now have a properly installed Butterfly Keel. Thanks very much for the help!!!
