Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
the unofficial home of the dumas dauntless
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 10-22-2012, 07:56 AM
  #3601
Rich404
Rich404's Avatar
Default RE: the unofficial home of the dumas dauntless
Hey Dauntlessfan,
I bought two more pumps. They happen to be the pumpthat's onthe top of your list. I like the idea that I can actually see the the motor can because I can monitor the temps or even water coolthem . Also, I agree and conclude that windshield washer pumps are no good for continuous running. We need pumps that can keep on going for long periods of time. With this said I may entertain watercooling them rightfrom the tap.
Also, I got an e-mail from offshore electrics that my 800 sized water jackets are in so I placed that order too. Hopefully in the next couple of weeks I can resumeon the watercooling system.
This is trial & error because I haven't seen many people that had an electronic cooling system in their boat.
-Rich.
Old 10-22-2012, 08:14 AM
  #3602
Rich404
Rich404's Avatar
generally speaking....
I noticed something about the lines on the Dauntless but I couldn't prove it until yesterday. Note on the side profile starting on the bridge shelter that the end of the shelter sideflows downward. Then, after the aft bridge deck it flows down again. Past that, just after the owners cabin it does it again in the cockpit area. Then, after the cockpit it flows down at the stern. When the water was streaming out of the transom guess what? they streamed the same exact way as the rest of the side profile. Ibelieve the side profile was designed to look like streaming water. It made perfect sense when the pumps were on. I think the reason why the wet exhaust was located so high up was to finish the profile designusing water. The water steamed out about 4-6" before it flowed down to the water. It looked perfect when following the lines of the boat.
-Rich.
Old 10-22-2012, 01:31 PM
  #3603
Sound Sailor
Calm down there big fella! Take a look. The engine water pump on the big guys don't sent out so much pressure as to have a 8' stream of water. It is a function in our scale even without a pump. I just added water cooling to the Baron and it comes out the side in a 6" arc without a pump.
Are you going to Queens Sunday?
Bill
Old 10-22-2012, 02:20 PM
  #3604
deep sky
hi captains here is the latest midnight oil work. after its painted ill plank the floor
ID:	1813980   Click image for larger version
ID:	1813981   Click image for larger version
ID:	1813982   Click image for larger version
ID:	1813983   Click image for larger version
Old 10-23-2012, 06:01 AM
  #3605
Rich404
Rich404's Avatar
ORIGINAL: Sound Sailor
Bill
Yes, i'll be there.. Are you going?
-Rich.
Old 10-23-2012, 06:02 AM
  #3606
Rich404
Rich404's Avatar
ORIGINAL: deep sky
It looks great DS!! You should have good access to the enginerom from there.
-Rich.
Old 10-23-2012, 06:15 AM
  #3607
Sound Sailor
See you there Bud. You bringing Dauntless? I hear there will be a buyer there!
I won't be bringing mine since re wiring not finished and been working on other projects.
Bill
Old 10-23-2012, 06:41 AM
  #3608
Rich404
Rich404's Avatar
Yes, i'll be there and will bring the Dauntless. wow it just occured to me that you never seen it in person yet.
Yep, I think the buyer will be wide-eyed when he sees the boat in person.
-Rich.
Old 10-23-2012, 02:25 PM
  #3609
deep sky
hi captains i started fitting the canopy top and found out that my radar mast was too short so i got to thinking now is a good time to make the forward stand for the radar mast .i know what the shape looks like i dont know how long or wide it should be can any one give me an idea
ID:	1814251   Click image for larger version
ID:	1814252   Click image for larger version
ID:	1814253   Click image for larger version
Old 10-23-2012, 04:00 PM
  #3610
Apismelifera
Apismelifera's Avatar
Rich404
Re water pumps. Have you looked at the water pumps that the "Water Cooled PC" crowd are using?
These move a lot more water than the smaller washer type pumps will, and are designed for continuous operation.
For example: http://www.frozencpu.com/products/14...c107s153#blank
One of these would be all that you need.
The link shows a complete pump. The pump body and the pump itself. Scroll down a little and you can see the list of available fittings. You would need a couple of hose barb fittings at the least.
Old 10-23-2012, 04:27 PM
  #3611
deep sky
i was not shure about the size so i looked at the pix what do you think
ID:	1814295   Click image for larger version
ID:	1814296   Click image for larger version
ID:	1814297   Click image for larger version
Old 10-23-2012, 04:54 PM
  #3612
dauntlessfan
dauntlessfan's Avatar
DS I think the Dumas radar mast was too tall as compared to the original. I cut mine down quite a bit in an effort to match Big D's profile. Rich/Bill do you know about how tall it should be in inches?
Old 10-23-2012, 06:58 PM
  #3613
deep sky
dumas calls for 5 7/8 tall i raised my bridge roof by at least 1/2 my radar mast is 6 3/4 here is more pix of the profile
ID:	1814363   Click image for larger version
ID:	1814364   Click image for larger version
Old 10-24-2012, 06:02 AM
  #3614
Rich404
Rich404's Avatar
ORIGINAL: Apismelifera
Rich404
Darn it!!! A day late & a dollar short! I just ordered 4 pumps from e-bay to test out. If these pumps are really inefficient I will give that one a go. It looks beautifulfrom a structual standpoint. At some point I alsoplan on updating the fansto be liquid cooled sothat may be a good time for upgrading the whole system into something really cool.. (hey a pun ) My goal first is to get this system to work & upgrades will have to come later on. Thank you for showing me that awesome loking pump.
-Rich.
Old 10-24-2012, 06:28 AM
  #3615
Rich404
Rich404's Avatar
ORIGINAL: deep sky
Too short no, too tall yes. This is a point when it is good to veer away from Dumas's plans and follow us if you want accuracy. Dumas has you putting that mast high up in the clouds where it doesn't belong. At different points of time Bill, DF and I tackled the mast. I took a break from the mast at a mid way point to focus on the electrical work but Bill finished his.
Here are a couple pictures of my mast from discussionsthat took place in the in the 120-130 page range. Note Herc is 4.25" tall. Unfortunately I won't have access to my boat for the next couple of days but perhaps someone else will chime in with info.
-Rich.
ID:	1814428   Click image for larger version
Old 10-24-2012, 08:37 AM
  #3616
dauntlessfan
Test post... getting '500 internal server errors' again... can't post pics...
Old 10-25-2012, 12:05 PM
  #3617
deep sky
hi captains here is the latest built a new helm got the radar mast step built still looks bad with no paint soon
ID:	1814735   Click image for larger version
ID:	1814736   Click image for larger version
ID:	1814737   Click image for larger version
ID:	1814738   Click image for larger version
Old 10-25-2012, 12:08 PM
  #3618
Rich404
Rich404's Avatar
Hey Deep, On the helm and the canopy frame what kind of varnish/paint are you using?
-Rich.
Old 10-25-2012, 12:26 PM
  #3619
deep sky
hi rich this is what i use
ID:	1814753   Click image for larger version
Old 10-26-2012, 06:25 AM
  #3620
Rich404
Rich404's Avatar
Hi Captains,
Yesterday Offshore Electrics delivered some of my watercooling goodies so this weekend the waterjackets will be installed on the Astroflight 25's. When I do that I am going to remove the 4 giant underwater scoops along with the Mercedes pumps. I don't think I ever posted pictures of the scoopsbut just as well because they won't be missed. On Sunday I am going to introduce the boat to Bill and the boat club for what is supposed to be the final club run of the season.I am expecting the first pair of new pumps to arrive any day now & the 2nd pair should be sometime next week.
-Rich.
Old 10-26-2012, 10:08 PM
  #3621
dauntlessfan
DS - Here are some reference lines drawn for the radar mast to hopefully show the height of the unit as it was on Big D.
Highest blue line is the plain where the actual radar unit was mounted.
Below that is the mast platform. Circled in red is the wind speed meter placed forward on that platform. If you want to add this detail, make sure it'll fit.
Next down is a roofline reference, then below that is the main deck line.
Old 10-28-2012, 06:36 PM
  #3622
deep sky
hi captains i did a little more work on the helm what do you think
ID:	1815742   Click image for larger version
ID:	1815743   Click image for larger version
ID:	1815744   Click image for larger version
ID:	1815745   Click image for larger version
Old 10-28-2012, 09:55 PM
  #3623
dauntlessfan
This weekend I abandoned the incorrect forward cockpit 'place holder' I've had on my Dauntless, and modeled the yacht's actual seating area.
How cool it must have been to sit in this spot while underway! Pics of my progress to follow.
Old 10-29-2012, 05:51 AM
  #3624
Rich404
Rich404's Avatar
Hey Dauntlessfan,
Funny you posted that I just installed the seat over the weekend.
The other night I did some work on the Dauntless to get it ready for a club run on Sunday. The large underwater were removed and some of the furniture that I have been hoarding was installed inside the boat. On Sunday it was very windy but I still ran the boat for the handful of guys that made it to the pond. We had a few sailboats in the water that were getting blown over because of the hectic wind gusts. The Dauntless on the otherhand proved to be awesome because of the independant throttles and power. I had complete control over the boat.
With the scoops removed the boat ran even better than before! Everyone that seen the boat was impressed with it.
-Rich.
Old 10-29-2012, 06:49 AM
  #3625
dauntlessfan
Hi Rich - last time I took mine out it was exceptionally windy like that. I left the canvas roof piece on shore because I thought maybe the wind might catch it and blow it off[X(].
Okay so here's pics of the conversion of my forward cockpit. Was much easier than I thought because I just repurposed the existing piece I made long ago from balsa and had already fiberglassed it for strength and waterproofing...
ID:	1815854   Click image for larger version
ID:	1815855   Click image for larger version
