RC Scale Boating Enjoy rc scale boating? Talk about it here.
the unofficial home of the dumas dauntless
Old 11-16-2012, 07:15 AM
  #3676
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: the unofficial home of the dumas dauntless
Hi captains,
I went ahead and deletedall the pictures that were not cooperating above and reposted them. They seem to work this time..Hopefully it will be better for all to see.
Sorry about the vanishing comentary Dauntlessfan. I had that happen to me a few times so now out of habit I highlight the entire text and copy it before submitting...This has saved me from redo's so many times...
The boat is much faster than in the past. In the short video the low voltage alarms were going off so she wasn't performing at 100% then leaves fouled the props when I turned the boat around...I am happy with her speed and seeing this big girl get up on plane is really cool.
I have to lay up Dauntless for a while. Her sound module is defective and I have to disconnect it and send it back to Canada. The speed controls are currently wired into the module. The defect was that when I turned on the sounds there was a piercing feedback sound coming from the speaker. According to the designer it should not be..
-Rich.
Rich404 is offline
Old 11-16-2012, 07:19 AM
  #3677
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Hydro Junkie
I couldn't get the right two on the top row to open. Is it just me or is there little evidence of Sandy in any of those pictures? My trip to Connecticut didn't show me much more than power outages though, due to my not going down by the coast, that might account for it
Hey Hydro...If you are ever in the area let me know & perhaps we can make arrangements to go sailing..
-Rich.
Rich404 is offline
Old 11-16-2012, 07:50 PM
  #3678
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi captains i hope all is well here is my latest pix i got somemore work done in the cockpit looking better all the time.i still dont know if i need 2 6 volt batt per esc or 1 12 volt batt for each esc or 2 12 volt batt per esc on these evx-2s any way moveing ahead
ID:	1821086   Click image for larger version
ID:	1821087   Click image for larger version
ID:	1821088   Click image for larger version
deep sky is offline
Old 11-16-2012, 10:53 PM
  #3679
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think i got it i need a total of four 6-8.4v packs so i get 16.8 volts.2 per esc i was  thinking that the graupner 700 bb turbo 9.6 would not handle the 16.8 but  the specks say it will
deep sky is offline
Old 11-16-2012, 11:07 PM
  #3680
dauntlessfan
dauntlessfan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: deep sky
Yes sir, that setup will be "plug-n-play" and those 700 bb turbo 9.6 motors should push her along very nicely! Your boat is looking remarkable too, by the way!
dauntlessfan is offline
Old 11-16-2012, 11:36 PM
  #3681
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my only question is when i hook it all up there are 4 motor leads if i am only useing 2 1 for each motor do i need to change any wireing
deep sky is offline
Old 11-17-2012, 03:54 AM
  #3682
Sound Sailor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More importantly you bettter see if your ESCs will handle that voltage or you are either going to burn them out or they will be shutting down all the time. Most Escs I have encountered will not take more than about 14v including the 208D. Also with that voltage those motors and esc will run hot so you will need water cooling. I have those motors in my Dauntless and run them on 12 v.. You can run with 1-12v NIMH per motor and the larger the mah of the batterythe more run time. If you put 2 12v INPARALLEL per motor you are still running on 12v per motor but you double the running time. If money is an issue i would start with 1 per and add the second later.
Here is a pic of my setup of 2 12v per motor . (total of 4 ) They are stacked 2 high with the 2 on the left for the port motor and the 2 on the right for starboard. To wire them, as I told you before, Y harnesses are available either in series or parallel. Series doubles the voltage while parallel keeps same voltage but doubles run time.I don't thinkI can make it any clearer than that.
If you have seen the videos of my boat you will know it moves well with 1 1/2" props and this 12vsetup. IMHO you are asking for problems if you go 16.8v even with the motors over any amount of time and i think Graupner and Mabucchi would tell you the same.
BTW I went the cheaper route with emergency gel pack batteries first and they would appear to go dead quickly. After sitting a few minutes they would recover for a while and repeat the cycle. Wound up being a waste of money so I replaced them with this setup. If you look on Ebay you can find good deals on 12v nimh batteries. go for the most mah you can for the most run time. Notice mine are 4200 mah. Still cheaper than GOODlipos.
pic of Y adapters One on left isparallel, one onright isseries. Notice on left red to red and black to black On right notce one side loops to other male plug. Plug on bottom (female )goes to ESC the two males at the topto the 2 batteries.
Bill
ID:	1821160   Click image for larger version
Sound Sailor is offline
Old 11-17-2012, 06:51 AM
  #3683
dauntlessfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No Deep you won't need to modify any wiring in the situation you described.
Old 11-17-2012, 06:59 AM
  #3684
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Deep,
Don't know why but none of yur pictures will download?  Seems to be a system problem.
All Captains,
FYI, there's a new Dauntless kit available on fleabay at item number 150946814054.  It has 6 days to go, started 9 days ago at  $0.99 and is now only $56.  Running hardware kit is included in the sale, kit 2332.  Just in case you know someone looking for a kit.
Bob
rblubaugh is offline
Old 11-17-2012, 07:07 AM
  #3685
Sound Sailor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
????? He is talking about 4 motor leads when he really means 4 battery leads since "motor leads" would be from the esc to the motor. He said he was going to use 4 batteries, 2 for each motor and each would be in series to get 16.8v. DF, are you saying you think he should be using 16.8 v to his esc and motor? If so we don't agree but have at it and it will be interesting to see how it works out.
Maybe it's me who is missing something here so I'll leave it at that and not comment further.
Bill
Old 11-17-2012, 07:36 AM
  #3686
dauntlessfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill, the EVX-2 is different from the typical ESC in that it has two battery input harnesses ( + and -) and two motor output harnesses ( + and -). It's advertised heavily by Traxxas as a 16.8 volt ESC since it can accept two 8.4 packs.
I'll post a few wiring diagrams tonight to clarify.
Old 11-17-2012, 07:40 AM
  #3687
Sound Sailor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see, I am not familiar with that esc (really different)but I still would not run those motors on 16.8 since that is probably the max with no load. I find it hard to believe they will last long and besides as we know the boat does not require that much voltage to run with those motors.
Bill
Old 11-17-2012, 07:59 AM
  #3688
dauntlessfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup I think 12 volts is probably the sweet spot both for the motors and this boat. I'll include that setup in the wiring diagrams.
Old 11-17-2012, 08:02 AM
  #3689
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dauntlessfan
Hi Dauntlessfan,
So the speed control takes in 16.8V and the output is (2) 8.4V jacks for the two motors?
In a perfect world I still think he would have been better off with the Astroflight ESC's..IMHO.
-Rich.
Rich404 is offline
Old 11-17-2012, 08:52 AM
  #3690
dauntlessfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Close but other way around, it takes in two batteries 6-8.4 volts and the output is double, up to 16.8V max. I'll clear it up by posting some wiring diagrams tonight.
Old 11-17-2012, 09:01 AM
  #3691
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get it now...one 6V battery input has a 12V output...
-R.
Rich404 is offline
Old 11-17-2012, 01:31 PM
  #3692
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what about running 2  7.2 packs for each  motor at a max volt of 17.4
deep sky is offline
Old 11-17-2012, 02:08 PM
  #3693
Sound Sailor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What that esc does is put the 2 batteries in series thereby doubling the voltage. That means you get the most votage out of the combo of 2 batteries but less run time. Not my cup o tea.
I opt for longer run times in my boats so all but one have 2 batteries in parallel.
Bill
Old 11-17-2012, 04:30 PM
  #3694
dauntlessfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: deep sky
Yes Deep that is correct and would work fine (your output voltage would be 14.4).
And yes Bill you are correct as well on the series statement as well.
Old 11-17-2012, 04:58 PM
  #3695
Sound Sailor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DF are you using this esc? Interesting reading the specs. Notice motor limit and about thermal shutdown. Also about the 0 timing for reverse
Bill
Motor Limit: EVX-2 Marine has a 12-turn 550 modified motor limit whenInsulate the Wires: Always insulate exposed wiring with heat shrink tubingUse Neutrally Timed Motors: For reverse use, the motors must have 0°Motor Capacitors Required: Ceramic capacitors should be properly installedNo Schottky Diodes: External schottky diodes are not compatible with
the motor is properly geared. A water cooling kit (Traxxas part #1580) is
required for modified motor use in marine applications such as the Villain
EX. If the motor or speed control is overheating, try a smaller pinion gear.
Do not attempt to use a more powerful motor (fewer turns) than the above
mentioned motor limits or you could experience frequent thermal shutdown.
to prevent short circuits.
timing. Modified motors (with adjustable end bells) timed to 0° or Johnson/
Mabuchi (closed end bell) motors are recommended. Using motors with
other than 0° timing will draw excess current in reverse, and can result in the
speed control overheating and premature motor wear.
on every motor to prevent radio interference. These are already installed on
the factory Titan Marine motor.
reversing speed controls. Using a schottky diode with the EVX-2 Marine will
damage the ESC and void the 30-day warranty.
Old 11-17-2012, 06:06 PM
  #3696
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my brain is getting so fryed about these escs i wonder if i should sell these and buy ? what are you outher captains useing for the groupner 700 9.6 motors as in batt-escs
deep sky is offline
Old 11-17-2012, 07:16 PM
  #3697
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My motors & ESC's are Astroflight and you see I have a no-nonsense setup...
I mentioned this time and time again..go for the Astroflight ESC's..
Here is what I find comical...So many people cut corners to save money and then have to spend even more moneyto do it all over again...I've seen this happen on the forums for years..
Isn't it cheaper to just do it right the first time?
-Rich.
Rich404 is offline
Old 11-18-2012, 11:19 AM
  #3698
deep sky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi caps i got a little more work done on the cockpit built the 2 benchs havent glued them down im thinking of puting hinges on them so i can get to my motor covers
ID:	1821519   Click image for larger version
ID:	1821520   Click image for larger version
ID:	1821521   Click image for larger version
deep sky is offline
Old 11-18-2012, 01:51 PM
  #3699
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice Deepsky!!
-Rich.
Rich404 is offline
Old 11-18-2012, 02:19 PM
  #3700
Rich404
Rich404's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is some photos taken today..
It's like a scene from YACHTS IN A HURRY...
-Rich.
ID:	1821570   Click image for larger version
ID:	1821571   Click image for larger version
ID:	1821572   Click image for larger version
ID:	1821573   Click image for larger version
Rich404 is offline
Display Modes
