Invader tug or Mister Darby kit
OH
RE: Invader tug or Mister Darby kit
You will spend quite a bit of time on either model. They are both big boats. Pick the one that interests you the most since you will be the one clocking in all the hours that they require. Are you a experienced builder? Have you built before?
Sorry this is not much help.[]
Marty
Marty
I'm not an experieced builder. I have the dumas 48 inch pt 109 but havenotfinished it yet. I would like to build a larger scale because the smaller parts arenot as small.
If your not an experienced boat builder it is better to start off smaller and simpler. That way you don't get discouraged and not finish a build. http://www.vac-u-boat.com/ is a great place for a new builder. You would get up and running much sooner than with a large model. The choice is always yours but this is the way I would go. The larger the model the more difficult it is to build. More experienced builders know what to look out for and be prepared for. Good luck on whatever you decide. Let us know what boat you choose.
Tug
Tug
FL
We are looking for a set of plans or instructions for the Mister Darby, does anyone have a set they can copy to my email? [email protected]
Charlie
Charlie
Hi Charlie,
I,ve bought Mister Darby from Dumas more than 10 years ago anda now I decided to built it but i lost the plans.... I see that you want it too in past. Do you have then?? Could you send then do me by e-mail???
Thanks a lot.
Jean Quadrado (from Brazil)
Thanks a lot.
