RC Scale Boating Enjoy rc scale boating? Talk about it here.
Donzi Powering
Reply
Old 07-30-2007, 10:46 AM
JSchneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Donzi Powering
That is what I experienced as well. I wish there was a way to tame the reverse a bit....
JSchneider is offline
Old 07-30-2007, 11:11 AM
u163665
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I look forward to seeing pictures and videos if possible!
u163665 is offline
Old 07-31-2007, 07:46 AM
JSchneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unfortunatly, I think it is a characteristic of the speed control, I tried everything and it was still over powering in reverse.
I will consider taking some pictures when I take it out the lake. Right now I have some modified universal joints installed that create some vibration, the new ones should arrive this week.
Old 07-31-2007, 12:32 PM
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JS: Do you have a computer radio? If so, you can dial out the amount of throttle travel in reverse on the transmitter and that will solve your problems.
Kmot is offline
Old 07-31-2007, 01:59 PM
JSchneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, it is not a computer radio. I think it is just characteristic of the speed control, when you pull the throttle back 1 click from neutral, the motor runs at least at 25%, which is dramatically unproportional to foward. Did you see this with your set up?
Old 07-31-2007, 02:30 PM
  #31
JSchneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you know if the Mini EV motor has 0 timing? I switched the wires going to the motor and it didn't make a difference which makes me think it has 0 timing.
Old 07-31-2007, 03:42 PM
  #32
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do believe it has 0° timing.
Kmot is offline
Old 10-02-2007, 06:49 PM
  #33
yjguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nothing like reviving and old thread. I ran my Donzi with a pair of 820 cans, they were on a set of FDM gear reduction units running a 3.25:1 ratio. this beat was swinging 2 1/2" 3 blade props. Each motor was running its own 208 esc. For battery power I had great luck with a D cell nicad 4800mah 14 cell pack. This boat would get over 20 mph. Not bad at all for a 28 lb boat. I could run it for 30-40 mins, not at full throttle, plenty of play time with this set up. I was looking into moving up to a 4.5:1 ratio before I got rid of it. that would slow it down a bit but I think it would have really improved runtime.
BTW, I had not watercooled mine, and it barely got warm, let alone hot enough for watercoolong.
I am building a Broom 44 now. Im building it with the Mini EVs running a 3:1 reduction. I plan on using only 12 D cells on this build. The EV has lower RPMs than the 820 (18k v 24k) if I remember correctly.
I have a ton of pics of my Donzi, I just cant find them. Kmot, you may remember them for RRR a few years ago. Ill see if I have them on a disc somwhere.
Good luck
Tom
yjguy is offline
Old 10-02-2007, 07:35 PM
  #34
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like this boat.What kind of hours is average to build it up,before paint and final touches?
nitro wing is offline
Old 10-02-2007, 10:41 PM
  #35
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
20 mph is cookin' on that big boat! u163665 has gone 12 mph on his and that seems fast!
Kmot is offline
Old 10-03-2007, 07:49 PM
  #36
DAMDONZI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nitro Wing, I'm in the process of building one now (when I can get the time...) I'm about 1/4 done and have about 85 hours in so far. The ammount of hours probably depends greatly upon how detailed you plan to build it. But from what I can gather from reading past Threads, these boats are a lengthy build...
DAMDONZI is offline
Old 10-03-2007, 08:09 PM
  #37
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well,I have built dozens of rc aircraft and work in a bodyshop,so prep and paint and glass work is easy for me.
I think this kit is discontinued though and honestly it is a bit large and tall.You guys need an open pickup truck to move it?
I do howver want to build a yacht or sport fish boat of similar looks,perhaps smaller and less involved.
Anyone have any ideas of kits I could look into?
I seen this link and there are some real nice boats on there.I dont think the kits are for sale though?
maybe I'll start another Yacht thread instead of derailing this one
Old 10-03-2007, 09:52 PM
  #38
yjguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
unfortunately there is not too much out there. I have searched with little success.
yjguy is offline
Old 10-08-2007, 05:47 AM
  #39
DAMDONZI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a question for all of you who have built a z65... Of all the pictures I have seen on the net of built models, I have never seen a boat built with the engine room air intakes built into the sides of the hull. I have seen pics of two boats with them painted on (one the older three square opening style, and one the newer "slot" style) Why doesn't anyone put them in? Does it weaken the hull? Too difficult to do? So many of these boats are bult to amazing levels of detail, there must be a reason why they are leaving the vents out... If it was to be done what material would be ideal, wood, plastistruct, sometinng else?
DAMDONZI is offline
Old 10-08-2007, 11:11 AM
  #40
yjguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was kicking around this just before I sold mine. I wondered the same thing. I had made the boxes for the vents out of 1/32" ply. I sealed them with some west systems epoxy. I never finished them or cut the hull. I dont think that it would make the hull weak a all.
doing this would add so much detail to the boat. It will look great! Good luck!
Tom
yjguy is offline
Reply
Display Modes
