More Joseph Daniels Build Pictures
RE: More Joseph Daniels Build Pictures
Nice work!
NE
Thanks! Had a little problem with some epoxy on the shaft causing a jam in my A strut. Could get the shaft out so now I am checking with kit manufactor about a replacement strut. Got some parts to make one but wont look the same. Oh well, I guess I will work on the deck until parts arrive.
Larry
Larry
NE
I cleared my jam by drilling it out on a drill press. No damage to the strut. Got another steel shaft from Lowes. Everything is lined up. Epoxied the struts in. Also build a helo to put on the pad.
NE
Did some dry fitting of the structors to see how it looks. I have most of them glued, just have to do the top ones first. Put my helo and pad on also. Will look better once everything is sanded and painted.
