Dumas 48" pt 109
RE: Dumas 48" pt 109
The last 2 are done, I just kinda figured how to up-load, When I tried to send all 6 at once it told me"unable to find rcuniv....."
Those are the $40 proboats, I have a Trojan with 2 Grapner 12v 700s that I control with only one proboat, no water cooling, but it does sit on an aluminum plate, I can hold the esc after I run it hard, the 12v 700 must not pull many amps, I use 1-3/4" Dumas brass 3 blade props with a 2" pitch, With 1-1/2" Dumas props I only get about 7mph, with 12v. I get about 13mph out of the trojan and about 14-15 from the PT boat with the 1-3/4" props.
Tried the mcd 480 with no water cooling on the pt boat and it cut out.
I have a 5mm round file that I found at the flea market. It takes about 3-5 minutes of working the 3/16" (4.87mm) brass Dumas coupling to get the 5mm opening. One you break threw, remove the file at once, because any extra smoothing will only make the coupline loose.
My Feedback: (61)
Hi,
Nice job so far! I love these old PT boats. Heres a few pictures of different ones I own or have owened in the past. Lotsa fun and you can scale them out very nicely.
Pete
Pete
My Feedback: (10)
hi
great looking pts, heres mine 5' scratch build ,i wish i would of use three motors speed runs out to early ,and heres a youtube page of my rc boats and other and a picture of are small club at our summer place we have a big pond in front great just 10' to water eage, thanks rye
http://www.youtube.com/results?searc...rch_type=&aq=f
NY
but a smaller prop will make it faster. you get more revolutions. many things can affect which prop size you need such as altitude and use of the boat.
My Feedback: (10)
what about this prop is the pitch ok? or any other one in this line can i use a two blade would that be better thanks rye
http://www3.towerhobbies.com/cgi-bin...?&I=LXRUD6&P=0
I ran 2 grapner 700s on 12v with 2, 1.5" dia., 3 blade 2" pitch Dumas brass props on my trojan, it did about 7mph , I brought it back to shore and swaped out the props for 1.75" dia 3 blade 2" pitch Dumas brass props and it did about 11mph, other people have had different results with simular tests. Randy
With viper 900, they are not that fast, but have a lot of tourqe, you could tirn 2" props. Those are low rpm motors, they must have a lot of turns to and thus have a lot of tourqe.
NY
me i use 2 Blade it better then 3 Blade ,then again i use gas engine .check out this link http://www.funrcboats.com/prop_chart1.htm
