1/96 USS Port Royal (CG-73) Build Log
1 Attachment(s)
I am formChina has started to build a 1/96 USS Port Royal (CG-73), a Ticonderoga class missile cruisers.I has posted a build log in one of the Chinese forums
Attachment 2235909 |
RE: 1/96 USS Port Royal (CG-73) Build Log
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><span lang="EN-US"><font size="3" face="Times New Roman">CG73 Port Royal Cruiser is the last Ticonderoga-class cruiser in us navy,I ordered this arkmodel kit months ago now it arrives.This is a new full kit in 1:96,arkmodel post semi kit many year ago,now it is all ready.This is first time I build a FRP kit,before this I built many plastic kits
http://i452.photobucket.com/albums/q...l/hoodsx/2.jpg http://i452.photobucket.com/albums/q...l/hoodsx/3.jpg http://i452.photobucket.com/albums/q...l/hoodsx/4.jpg http://i452.photobucket.com/albums/q...l/hoodsx/5.jpg http://i452.photobucket.com/albums/q...l/hoodsx/6.jpg </font></span></p> |
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><span lang="EN-US"><font size="3" face="Times New Roman">As usual, the first step is shaft and rudder system installation positioning.Due to the relatively large size,so use the<span style="mso-spacerun: yes"> </span><chmetcnv unitname="mm" sourcevalue="5" hasspace="False" negative="False" numbertype="1" tcsc="0"></chmetcnv>5MM shaft,The shaft tube use own bearings and stainless steel .pipes,the rudder with the Ark Original rudder.</font></span></p>http://i452.photobucket.com/albums/q...l/hoodsx/8.jpg
http://i452.photobucket.com/albums/q...l/hoodsx/9.jpg |
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3"><span lang="EN-US"><font face="Times New Roman">ARKMODEL original driver is 550 with gearbox,it's a mature power but the noise is too large...To drag propeller </font></span><span new="" times="" style="font-family: 宋体; mso-ascii-font-family: ">(</span><span lang="EN-US"><font face="Times New Roman">diameter is <chmetcnv unitname="mm" sourcevalue="54" hasspace="False" negative="False" numbertype="1" tcsc="0"></chmetcnv>54MM</font></span><span new="" times="" style="font-family: 宋体; mso-ascii-font-family: ">)</span><span lang="EN-US"><font face="Times New Roman">,I think that the 550 motor is not enough,so I purchased 775 motor.
http://i452.photobucket.com/albums/q.../hoodsx/10.jpg http://i452.photobucket.com/albums/q.../hoodsx/11.jpg</font></span></font></p> |
have no the cnc machine,so all the extra plates had cut by hands,was very strenuous.The big ships strengthening work should do a good so use a more ABS board. The rudder sysytem was completed
http://i452.photobucket.com/albums/q.../hoodsx/12.jpg http://i452.photobucket.com/albums/q.../hoodsx/13.jpg http://i452.photobucket.com/albums/q.../hoodsx/14.jpg |
<p class="MsoNormal" style="margin: 0cm 0cm 0pt"><font size="3"><span lang="EN-US"><font face="Times New Roman">The position of the servo set under VLS system below,easy to maintenance in the future. use the glass fiber cloth + epoxy and the hull fixed</font></span><span new="" times="" style="font-family: 宋体; mso-ascii-font-family: ">,</span><span lang="EN-US"><font face="Times New Roman">then use the wood to strengthen.
http://i452.photobucket.com/albums/q.../hoodsx/15.jpg</font></span></font></p> |
Tired of doing hull, Start to do a superstructure, ABS sheet bonded with wood reinforcement, http://i452.photobucket.com/albums/q.../hoodsx/16.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/17.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/18.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/19.jpg </p> |
Because it is a new product this year, so today received the remaining resin parts, CNC parts, ispired my interest in superstructure.
http://i452.photobucket.com/albums/q.../hoodsx/20.jpg |
The hull is all fundamental, Superstructure needs with the correct hull, so still need to complete the hull. Polished Bi keel, dill holes fixed
http://i452.photobucket.com/albums/q.../hoodsx/21.jpg |
The fiberglass hull have a feature, hull need to add support, Otherwise opening will be increasing, This has been a little expansion. Fortunately, the hull is relatively thick, both sides of the holes, countersunk head screws and wood pulled.
http://i452.photobucket.com/albums/q.../hoodsx/22.jpg http://i452.photobucket.com/albums/q.../hoodsx/23.jpg |
Plus support, plus the deck edge strips, spend N hours to do, and spent N hours to adjustment, Finally completed.
http://i452.photobucket.com/albums/q.../hoodsx/24.jpg |
<span lang="EN-US"><font face="Times New Roman"><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font size="3">Put up the just-completed superstructure, the resin pieces pendulum bit., Beginning to take shape.</font></span>
<font size="3">http://i452.photobucket.com/albums/q.../hoodsx/25.jpg </font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/26.jpg</font></span></p></font></span> |
Mounted motor stand, Then mounted the motor to test. http://i452.photobucket.com/albums/q.../hoodsx/27.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/28.jpg </p> |
775 motor requires a separate ESC, also need a bunch of battery, feel the comparative costs of electricity. http://i452.photobucket.com/albums/q.../hoodsx/29.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/30.jpg </p> |
Aluminum motor stand can't installed because of the location of reasons,had to use copper motor stand, and with AB glue fixed plus fiber cloth. http://i452.photobucket.com/albums/q.../hoodsx/31.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/32.jpg </p> |
Port Royal, a Ticonderoga-class blue bilge + Gold Anchor unique, very unique. http://i452.photobucket.com/albums/q.../hoodsx/33.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/34.jpg</p> |
Main gun is resin
http://i452.photobucket.com/albums/q.../hoodsx/35.jpg |
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; BACKGROUND: whitesmoke; VERTICAL-ALIGN: top"><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #333333; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-ansi-language: EN">Evening started,do small things with ABS plus wooden structure,</span><font size="3"><span class="hps"><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #333333; mso-ansi-language: EN"> </span></span><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #333333; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-ansi-language: EN">On shafting the middle</span></font><span lang="EN-US" style="FONT-FAMILY: Arial; COLOR: #888888; FONT-SIZE: 10pt; mso-font-kerning: 0pt">.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/36.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/37.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/38.jpg</font></span></p> |
<span style="font-size: larger"><span style="font-family: Arial">The base of the electronic, raise waterproof, remove the maintenance is also convenient. <span lang="EN-US" style="mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">a</span><span lang="EN-US" style="mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: 宋体"> night to do this thing. </span></span></span><span lang="EN-US" style="font-family: 宋体; font-size: 12pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: 宋体"> </span>http://i452.photobucket.com/albums/q.../hoodsx/39.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/40.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/41.jpg </p> |
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; BACKGROUND: whitesmoke; VERTICAL-ALIGN: top"><span lang="EN-US" style="FONT-FAMILY: 宋体; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">ABS board arc relatively trouble,</span><font size="3"><span lang="EN-US"><font face="Times New Roman"> </font></span><span lang="EN-US" style="FONT-FAMILY: 宋体; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">I carve strip later on Putty blunted,</span><span class="hps"><span lang="EN-US" style="FONT-FAMILY: Arial; COLOR: #333333; mso-ansi-language: EN"> </span></span><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #333333; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-ansi-language: EN">One night to do a chimney</span></font><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #888888; FONT-SIZE: 10pt; mso-font-kerning: 0pt; mso-ansi-language: EN">
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/42.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/43.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/44.jpg</font></span></p> |
<p align="left" class="MsoNormal" style="TEXT-ALIGN: left; MARGIN: 0cm 0cm 0pt; BACKGROUND: whitesmoke; VERTICAL-ALIGN: top; mso-pagination: widow-orphan"><span lang="EN" style="FONT-FAMILY: Arial; COLOR: #333333; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-ansi-language: EN">The completion of the two chimneys</span><span lang="EN-US" style="FONT-FAMILY: Arial; COLOR: #888888; FONT-SIZE: 10pt; mso-font-kerning: 0pt">,</span><span lang="EN-US"><font face="Times New Roman" size="3"> </font></span><span lang="EN-US" style="FONT-FAMILY: Arial; COLOR: #888888; FONT-SIZE: 10pt; mso-font-kerning: 0pt">temporarily fixed to the superstructure.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/46.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3"> http://i452.photobucket.com/albums/q.../hoodsx/47.jpg</font></span></p> |
As the hull very large, Bought a bunch of industry self-painting, as a primer test http://i452.photobucket.com/albums/q.../hoodsx/48.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/49.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/50.jpg </p> |
Intend into the water over the weekend, ready for anything work, this superstructure seemingly simple upper but spend a lot of time http://i452.photobucket.com/albums/q.../hoodsx/51.jpg</p> http://i452.photobucket.com/albums/q.../hoodsx/52.jpg </p> |
<p align="left" class="MsoNormal" style="TEXT-ALIGN: left; MARGIN: 0cm 0cm 0pt; WORD-BREAK: break-all; mso-pagination: widow-orphan"><span lang="EN-US" style="FONT-FAMILY: 宋体; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">Today,bi keel conveying loose, resulting in leakage</span><span style="FONT-FAMILY: 宋体; FONT-SIZE: 12pt; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">,<span lang="EN-US">after site repair, and finally the successful sea trials.
</p></span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/53.jpg </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/54.jpg </font></span><span lang="EN-US"><font face="Times New Roman" size="3">http://i452.photobucket.com/albums/q.../hoodsx/55.jpg</font></span></p> |
