RC Submarines RC submarine discussions.
Acrylic WTC Cutting
Reply
Old 12-31-2013, 05:29 AM
dgxco1
dgxco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Acrylic WTC Cutting
I have a 36" long piece of Cast Acrylic Tubing 104mm x 110mm and need to cut to length 29".
Need the cut to be as true and flat as possible for the end caps to seal. Local machine shop wants $350 to cut!!
I looked at a few you tube videos showing how to use a table saw but since I dont have one that is
another $300 option. Any other ideas on how to cut this stuff without chipping or cracking the material?
dgxco1 is offline
Old 01-05-2014, 12:16 PM
danielplace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wood cutting 12" chop saw will make a clean straight cut.
danielplace is offline
Old 01-07-2014, 10:55 AM
bijou
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Angry
HI,
You may tray these:
- Cut a piece of metal sheet , thickness at least 1mm - 1.5mm , minimum width 100mm and having a length equal to at least 1 1/2 longer than the length of the circle that has wtc ..... roll the sheet where do You whant to cut as tight as You can.... overlaps the sheet perfectly aligned and then draw with something to stay visible and You are ready..... you solved
Less EXPENCEIVE and "piece of cake"
MARIUS
bijou is offline
Old 01-15-2014, 10:05 AM
dgxco1
dgxco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I actually cut the 4" cast acrylic tube on a table saw with a 90tpi carbide blade by rollng over the table blade with the tube.
Came out perfect not cracks, no chips and flatter than factory cut.
WTC is just about done, I had to make custom o-rings 1mm larger than the factory supplied since the acrylic is a little thinner than the PVC tube they provided.
Cant beat seeing the internals. Need to do a pressure check then try to figure out how to connect the x-tail to the 2 pushrods.
dgxco1 is offline
Old 01-16-2014, 02:28 AM
bijou
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default WTC cutting
HI ,
I am glad You did a fine cutting. What was the rotation NR of the blade during cutting?.
You didn't say on what submarine You are working?...if is not a secret
Can You add some photos with Your work until know? .
MARIUS
bijou is offline
Old 01-21-2014, 09:02 AM
dgxco1
dgxco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Standard rotation on the saw blade, set height 1/8" higher than thickness of acrylic. The trick is to have a perfectly flat surface against the guide and to rotate the tube smoothly. It is also important to have a carbide blade with a higher tooth count no offset and staggered grind on the teeth,
I am building an Arkmodel A212A U22 sub. I will post some photos when I can. My biggest complaint is the lack of support from the manufacturer and having to pay to get parts that were missing from the project kit. The supplied documentation is very limited.
dgxco1 is offline
Old 01-22-2014, 01:44 AM
bijou
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by . My biggest complaint is the[COLOR=#800000
[/COLOR] lack of support from the manufacturer and having to pay to get parts that were missing from the project kit. The supplied documentation is very limited.
I know what it meas and is to bad for them because an unsatisfied costumer is not gonna buy again fro them so I don't understand these policies !!!.Is bad for business in a long term .
I have a 212A type sense 2010 and is steel unfinished because of some Piston tank glitches unsolved no mater what I drayed .Now is dismantled and I use parts for another project .
If You use the same system : 12V/TAE Piston tanks may be I can find an answer for my problems.
MARIUS
bijou is offline
Reply
Display Modes
