has anybody else had this problem?
My Feedback: (61)
I have been using sealed batteries for years without any problem. A friend told me recently to not use them anymore as the sub could build up hydrogen gas (from charging) and explode. He had told me this had happened to him whilst the sub was underwater and underway. All of my boat (surface craft or otherwise) are using these types of batteries and I have had no trouble with them. Is he all wet? (so to speak)
Pete Olson
There are two types of ships: submarines and targets
Pete Olson
OH
RE: has anybody else had this problem?
sealed batts can give off gas. If you check the expensive subs and some sites you see that the sealed areas or WTC's (water tight compartments ) usually have a one way valve or air/pressure release system to allow the gas to escape.
SLA's gas during extreme charge or discharge. My sub has the SLA's in the wet part of the sub, so gassing is not a problem. DO NOT seal a lead-acid battery in your WTC. You will eventually have it explode, destroying your submarine and ruining your whole day.
If you need to keep your batteries in a sealed area, change up to NiCads or other similar battery. If you can, just move your SLA's outside your WTC into the wet area of your sub and you won't have a problem.
Bob the Builder
www.rc-sub.com
Bob the Builder
www.rc-sub.com
OK
Pete,
It just depends on what you're calling a 'sealed' battery. The usual 'sealed' lead-acid battery (like an automotive battery) isn't really sealed. It isn't easy to get into them (sort of), but they have to be vented or they will explode (or more accurately, rupture the case). If you're talking about a 'gel-cell' battery, then they won't explode unless you really do something silly like crack/puncture the case. The aren't 'position sensitive', you can mount them up/down/sideways with no problem. No openings in the case at all, so nothing will leak out, hydrogen gas or electrolyte. Of course, if you get them too hot, then sure, they'll cause problems.
Lead-acid batteries are not 'good' for models because of the vented hydrogen, and more importantly, because of the sulfuric acid content of the fumes. Causes a 'meltdown' of whatever the model is made from and you end up with a disolving boat. (Also causes @#$% with the 'life' in the pond where you're sailing.)
If your's, or your friend's gel-cell exploded, then you/he must have been doing something really 'odd'...
- 'Doc
- 'Doc
It will explode if you seal a battery in a container and charge it time after time, it is true, havnt you noticed that on every battery pack the instructions say 'do not charge in a sealed container'
do you mean a Sealed lead acid battery, they are fine but look at the back of them they have a pressure nipple to let gas out,
if the container its in is open when you are charging the battery you have nothing to worry about
Paris
Paris
