Go Back  RCU Forums > RC Boats > RC Submarines
Reload this Page >
The Aquathrust Vector Drive
RC Submarines RC submarine discussions.
Old 02-18-2010, 09:55 PM
AQUASUB
Default The Aquathrust Vector Drive
I have always wanted to build this kind of unit for variuse raesons one no need for fins of any kind on on vertualy any hull designe even hulls not intendid for water but space!
I knewI had a challange coming and after alot of reserch to find the right mini jet drives and most of all the Vector Ball head and how to make it,it finaly was a reality the other night.The ball is a solid ball in a socket that is smothe in operation and that can be moved by servos with high precition as that is very important with a Vector Drive as slopyness is not good.
Just about any type of motor can be used depending on how fast you want it to go and your space available for it,I will use brushless motors water cooled of course just like on the boats though not necessary since the impellor is so small and high torque not that necessary iether in most aplications but there definitly available with these motors ,bruched work very well, also even those Red bilge pumps can be used.
There are 2 sizes so far this one is the smaller the next is about double in diamiter and is good for those big subs that require even more thrust.Both can be installed in tandem and offer unparalled manueverability and reliability as its so simple,no more weeds getting in the prop no worries about hitting them but most of all the smothe manueverse like a Squid can only do!
To me this is the future of subs to come in both RC and full scale as hull designes and speeds and munuverability demands a different more advanced drive.
Kind of like the eveolution of the prop aitcraft to what is now in the Jet Age what a difference! Imagine if the Jet Engine never came to be.
Well here is a vid of the AquathrustVector Drive prtotype.
Old 02-18-2010, 10:12 PM
AQUASUB
Default RE: The Aquathrust Vector Drive
http://www.youtube.com/watch?v=jlRPHrhM73s
Old 02-18-2010, 10:20 PM
AQUASUB
Some examples of future upcoming subs ,yes subs like no other these will be! Finaly it can be done.
Dave Amur Sub Yard
ID:	1382098   Click image for larger version
ID:	1382099   Click image for larger version
ID:	1382100   Click image for larger version
ID:	1382101   Click image for larger version
ID:	1382102   Click image for larger version
ID:	1382103   Click image for larger version
ID:	1382104   Click image for larger version
ID:	1382106   Click image for larger version
Old 02-18-2010, 10:43 PM
AQUASUB
Here is a taste of whats to come but this one is here today and is one of my most favorite subs the Octura XL .
This sub uses a graupner Jet drive and a regular can 12 volt motor water cooled and this is going at about 1/4 thraughtle ! She is very fast super manuverable and very preciese in the water a joy to fly yes thats right fly in the water.
http://s82.photobucket.com/albums/j2...1-20-08051.flv
This sub fitted witha Aquathrust Vector would be even more manueverable.
She turns in about a foot or less and rolls to about 45 degrees very cool indeed.!
Dave
Old 02-19-2010, 12:45 AM
Father_Knows_Best
It looks a lot like the top of a roll on anti-perspirant bottle that has been modified. Are these parts all custom machined, or is this a modification of existing materials?
Old 02-19-2010, 10:10 AM
Captain Nemo12
Captain Nemo12's Avatar
That's a beautiful pond you're running in! Must be fun steering your subs through the arch underwater
Old 02-19-2010, 08:38 PM
AQUASUB
Its A blast like no other and thats only one of the features at this Den The devils Den.
Dave
Old 02-19-2010, 09:16 PM
AQUASUB
Just got the mini jet drive units and will be testing them ,these will be matted to the Vector head to make the Aquathrust Vector Drive.
These mini jet drives are amazingly powerfull and compact that make them idel for subs,motor shaft 2mm?,but standard mounts great for brushles motors.
Removed from the NQD jet boat there a great deal at 29.00$
Dave
ID:	1382693   Click image for larger version
ID:	1382694   Click image for larger version
ID:	1382695   Click image for larger version
ID:	1382696   Click image for larger version
Old 02-21-2010, 05:36 AM
junglelord
ORIGINAL: Father_Knows_Best
Yes, ingenious....
Old 02-21-2010, 09:12 PM
AQUASUB
Thank you Junglelord,yes on both ,you guys are sharp!
Old 02-21-2010, 09:23 PM
junglelord
Not as sharp as you!
Kudos to you...its brilliant!
Old 02-22-2010, 02:14 AM
Father_Knows_Best
Very cool stuff.
Old 02-22-2010, 04:02 PM
AQUASUB
Yes wait till you see it operational!
Dave
Old 02-25-2010, 10:52 AM
Rick Teskey
Hi Dave
I made a reply too the thread in the seaview thread and did not know your thread was here
Rick Teskey
Old 02-25-2010, 09:44 PM
AQUASUB
Yes I saw it ,and yes the 4 point pivot is good also and will probably make mine that way as well as that was the original designe but for simplisity and less passthrews I kept it at 2 rods,with the advent of a computerized  radio the transitions are so smothe that the stres on the linkages and ball are far less than a regular radio set up.
Ill be using this Vector Thrust Head on a jet frive and at full power the unit will be subject to great forces ,fortunatly so far the ball rotates  very smothly at about 45 psi which translates to several pounds of thrust at that apature!
It will come in 2 sizes so far large subs and small subs.
Dave
Old 02-25-2010, 09:57 PM
AQUASUB
Sofar the mini jet drive is very good! There super powerfull just a bit less at 12 volts than the Graupner units at half the price and size!
Ill be installing them 2 each in my current build the Royall Naboo Starship ,I will run the  motors in the wet ,watercooled of course from prescription pill bottle fits perfect and sealed.
Only the jets ,no need for the Aquathrust unit in this build,she is going to be a beuty!
Dave
Old 02-26-2010, 03:01 AM
Noibla
It looks a lot like the top of a roll onanti-perspirant bottle that has been modified. Are these parts all custom machined, or is this a modification of existing materials?
The anti perspirant bottle isBall or Arseol?
Old 02-26-2010, 09:25 PM
AQUASUB
Ball ,and the brand is important.
Old 04-01-2010, 10:02 PM
junglelord
That would be so perfect for a Star Ship Enterprise 1/350 conversion to submarine.
[8D]
Lots of other things too!
