Dumbest Tanker EVER!
RE: Dumbest Tanker EVER!
ORIGINAL: Fireman Tim
[sm=what_smile.gif]
Egg, I am going to go drink those two bottles of wine you gave me and try to forget everything I just read.
[sm=what_smile.gif]
I've ordered the RX-18 board, a Jagd Panther , and some sundry electronics connectors. I plan to have the Sherman up and running and hopefully shooting BB's and IR beams by Oct 23rd.
ORIGINAL: Eggman1965
I've ordered the RX-18 board, a Jagd Panther [img][/img], and some sundry electronics connectors. I plan to have the Sherman up and running and hopefully shooting BB's and IR beams by Oct 23rd.
Jim
#31
[quote]ORIGINAL: 1sgt
The HL BB shooter uses the left "up" joystick while the IR fires via the main cannon button. I mounted the IR diode beside the main barrel like a coax machine gun. So now (when they were both working) I can shoot BB's and IR. The IR diode can sit in the same place as the red "gun gonna shoot soon" LED warning light.
#32
[quote]ORIGINAL: Eggman1965
ORIGINAL: 1sgt
The HL BB shooter uses the left ''up'' joystick while the IR fires via the main cannon button. I mounted the IR diode beside the main barrel like a coax machine gun. So now (when they were both working) I can shoot BB's and IR. The IR diode can sit in the same place as the red ''gun gonna shoot soon'' LED warning light.
Jim
#33
Man that bridge just came out of nowhere!!! lol
ORIGINAL: ksoc
You could have just kept quite, and no one would have been the wiser.....
At least you didn't screw up with and audience present.... with CAMERAS!
#34
The tanks is an OTB MATO Sherman M4A3 (76)W. Fireman Tim installed the IRLEDin a piece of plastic pen barrel so it shoots through the hole where the red LED used to be. I copied this design on my HL Tiger so my son and I could shoot it out.
The IR LEDis the one with the hot glue holding it in. (Ain't pretty but it works)
#35
Oops missed a shot! Also I have taken my old burned out RX 18 board and scavenged the female pin plugs. My goal is to make the turret detatchable so there are no wires soldered to the hull without plugs. (It's a pain working on turrets with bits of plastic hanging off them.)
BTW can someone tell me what is supposed to be mounted at the bottom of this Tiger hull where the screw posts and the locator post are??
