1/4 scale Walker Bulldog
I've broken one of the front idle wheels although the stub is still ok but I can't find anywhere to get a replacement wheel.
Does anyone know if they'r avalable or is there an alternative.
Cheers vroooOOOM
Cheers vroooOOOM
RE: 1/4 scale Walker Bulldog
try Mato toys, they don't show them listed but they typically part out tank kits and have a lot of spares that aren't listed....they've always helped me out when I needed something... http://matomart.com/product.php?c=1000061
First thing if this is 1/4 scale and I would check that it is and not 1/16 scale then it will be scratch built this means there will be no off the shelf parts and you will have to make one yourself, if it's nearly 3 meters long then you are in the right area if it's around 300mm long then it's 1/16 scale there is a large difference between the two.
