The progress of an RC tank newbie...HL Panther G
ON, CANADA
So, last night I took my first small steps forward and installed the metal wheels and metal tracks on my HL Panther G.
Not being the handiest of individuals, I was rather pleased with myself when it was all done and I hadn't broken anything.
My enthusiasm was a bit short-lived however when I discovered, what I'm sure many of you have, that the standard HL Panther G suspension sags considerably under the weight of the metal tracks. The tank itself now bounces and rolls around under the weight, even when driving on a flat surface.
I mistakenly assumed that when I bought the upgraded kit with metal parts, that they would be essentially plug and play - and the existing suspension would be a good fit for the overall kit.
In any case, where do I go from here? Given my limited experience with such things, I'd prefer to avoid drilling and clocking the existing springs.
Are there some heavier upgraded springs that I can purchase that are well suited to the HL Panther G with metal tracks?
The tank rode great on the plastic tracks, so until I get a suitable suspension solution for the metal tracks, I'll be reinstalling the plastic ones.
TIAfor the advice.
TIAfor the advice.
RE: The progress of an RC tank newbie...HL Panther G
You can get stiffer springs from several retailers,here are a few examples:
http://www.rc-tank-world.com/1-16-H-...S-PRCSN-60.htm
http://supremerc.com/asiatam_upgrades.php
http://www.welshdragonmodels.co.uk/a...ther-591-p.asp
http://www.rctank.de/product_info.ph...roducts_id=805
ON, CANADA
ORIGINAL: Buckeye36
Is there one in particular you would recommend?
As well, are upgraded metal swing arms a useful addition or are the original plastic ones functionally just as good?
ON, CANADA
Thanks - I just sent Phil a note at RCTankWars inquiring about the springs and upgraded swing arms. Might as well do them both while I'm in there.
AB, CANADA
Metal wheels and tracks should have no effect on the spring weight of your model. Only thing supported by the springs will effect this. The wheels and tracks are unsupported weight. Ie they make up the part that stays on the ground!!!!
YHR is right its like your car the weight of the tires and wheels or anything on them don't have any affect on your suspension system.
Although there might be a slight affect because of the way the tracks rest on the support bogies and the sprockets and idlers aren't "springed". But I don't think there shouldnt be enough to cause problems...
I ordered an Jagdpanther with metal upgrades and it arrived today. The only issue I have is the gap between the sprocket and the next supporting wheel - when it climbs obstacles the track just bends into a funny shape. I wish I could post a video of that to show what I mean, perhaps I didn't explain it very well. I wonder if your issue is similar or totally different? Btw I assume the Panther G and the Jagdpanther share a common wheelbase.
I am trying to picture what you are talking about...if it sounds like I think it does I had a similar problem with my KV-1 when I got it and it had metal upgrades...but that gap actually helped it climb better...does your problem hinder its preformance?...problem might be different...
Not really, it just looks funny/unnatural. My KV 1 doesn't exhibit that behavior but the sprocket on the KV is at the back, so maybe I'll test it in reverse mode, the track could be doing a similar shape.
ON, CANADA
ORIGINAL: tankmaster5001
I'm new to this, but that analogy of to a car doesn't seem correct to me. I understand that that weight of wheels and tires wouldn't weigh on a car's suspension, but ~20% of the weight of the tracks are weighing on the drive and idler wheels (which are not suspension components).
As I see it, the net effect on the suspension is as if I added a comparable amount of weight to the hull of the tank.
In any case, there's no question that the suspension is not up to the task as is, whereas it was fine with the plastic tracks. Maybe I simply got a soft suspension which was borderline from the outset, and the small amount of additional weight pushed it past its limits.
Right which is why I edited it with the second paragraph...but I don't think the difference should be enough to suddenly change the suspension by as much as you described...I guess the springs could be very weak...
ORIGINAL: vano12
Do you mean it kinda folds itself on the underside of the sproket? If that is the, real tanks do the same thing. You may need to install a idler adjuster to tighten your track a bit??
Jim
AB, CANADA
ORIGINAL: Capt.Canuck
Although there might be a slight affect because of the way the tracks rest on the support bogies and the sprockets and idlers aren't ''springed''. But I don't think there shouldnt be enough to cause problems...
Thanks Jim, you explained it much better than my poor attempt. It does fold itself inward, is it true the real JP/Panther did the same? I have to dig up some WW2 footage. So what exactly is the best way to keep the tracks tight, tighten the spring on the first idle wheel after the sprocket?
Vano 12,
First off, if your tracks are staying on , ie: not coming of the idler wheel and it runs smoothly, I would let it alone. The two ways of taking up track tension is to install an adjustable rear idler. This allows you to move the idler wheel a bit forward or backward which ever the case may need. The other way is to remove a link from the tacks themselves. A word of caution, you do not want the tracks to tight as this could damage your gearbox or blow your main board. My Jagdpanther does the same thing, however as I mentioned, real tracked vehicles do as well, so I'm happy. My tracks stay on it runs good and I think it is one of the coolest AFV out there.
Jim
Jim
You could try removing a tracklink to shorten the track and eliminate some sag.
On edit; I should have read the above before posting! Apologies.
Thank you and the others for the feedback. No, it doesn't come off at all, and especially after I saw a video of a real JP doing the same I am more than happy to leave as is.
Vano12,
Good idea, like they say, if it's not broke, don't try and fix it. If your running metal tracks like I am, sooner or later we will both need to either get adjustable idlers or take a link out as I have hear the metal tracks tend to stretch quit a bit with usage.
When the time comes, I'll opt for the adjustable idler.
Jim
Jim
I think shortening the track would be easier for me, I have no idea how to install an idler as I am new to this. Maybe I will learn by then.
Vano12,
Well, I have had my Jagdpanther for about a year and a half, so I think I'm a bit closer to putting the the adjustable idler then you are so, I'll let you know how it goes.
I put adjustable idler mounts on my jagd and so far it has not thrown a track. They only took about 3 hours to install even with the instructions in German!
I have metal tracks and have clocked the springs and she rides great. I only clocked the first and last two on each side to the 8:00 position, the middle ones I left stock.
ON, CANADA
ORIGINAL: Pah co chu puk
Cost and time savings.
It was late one night and I thought, how hard can it be? It took a couple of hours of relaxed tinkiring. To order new springs would take two weeks and cost money, this was free. I do plan to upgrade to metal wheeles, swingarms and stronger springs someday, perhaps when I upgrade to 3:1 gears.
