Rovio meets Jagdpanther
FL
http://www.iheartrobotics.com/2010/0...o-hacking.html
That is the Rovio controller board. I want to install at least the control board and get video and if I'm sucessful with that, maybe try and splice the motor controls so I can control the tank with the web interface. If I run the rovio power in parallel with the tank power will the voltage be enough?
Here's the battery specs for Rovio:
http://www.robocommunity.com/article...pecifications/
Since Rovio's movemnt is very similar to a tanks (minus the third wheel), I think I may be able to use the default controls for Rovio to control the tank using just the front two motor controllers (which work without the wheel sensors).
What say you?
What say you?
