Pantiger Question
Pantiger Question
Good day tankers
I have a Glorious Pantiger that throws its tracks when operated on grass. I found that there is a bit of play in the rear idler wheels, so I separated the wheel in to two parts only to find that there is no screw to take off the wheel.
It has what looks like a nail head, posably a pressed in fastener. Has any one taken a pantiger apart and found this to be the case, if so how do I take off the idler?
I wish to place a few small walsher behind it to stop the play any ideas ??
Plan B, is to pull out the fastener and replace it with a small nut (thats me) and bolt. sound good ?
Capt. A
Capt. A
RE: Pantiger Question
It is a pressed in pin. There are no threads, it pulls out with some force.
To replace it with a bolt, you will need a 4mm by at least 30mm bolt.
