Recoil with modifications
AB, CANADA
I had a comment on another forum that it would be be great if I could slow down the return slightly. So I did
[youtube]http://www.youtube.com/watch?v=wamt0dlofsU&feature=youtu.be[/youtube]
RE: Recoil with modifications
i want to do that to my gun that i made mine is done with a smoker so it don't some unless i take the wire off from the batteries
http://s1009.photobucket.com/albums/af220/airbrushler/?action=view¤t=PDR_1523.mp4
NY
Uh...woa! This is great! Is it a development of a post Isaw a while back called something like "recoil from an elevation motor" or somesuch? YHR, I'd REALLY like to be able to replicate this. Ican see how the mechanicals work, but what did you do to change the electricals? Can you give any details, diagrams or instructions? Puh-LEEZ? Keep up the great work, and as soon as Iget my M4A1 Early conversion kit you KNOW I'll be hitting you up for electronics!
Andrew
Andrew
AB, CANADA
Actually the other post I did on this recoil showed the electrical set up. Only modifcation I made was adding a 68 ohm resistor to negative supply voltage.
NY
Yeah, I remember looking at that and thinking "oh, cool, I need to bookmark this!" and then getting distracted and forgetting...d'oh! Unfortunately I can't find it now, would you mind linking back to that other thread? Thanks man!
Andrew
Andrew
AB, CANADA
Here you go
[link=http://www.rcuniverse.com/forum/m_10885043/anchors_10885043/mpage_1/key_/anchor/tm.htm#10885043]Recoil thread[/link]
