Hen long Antennas
Hen long Antennas
I have several HL tanks with different frequenciesand all the external tank antennas are exactly the same length 13 and 1/8 inch. I thought you
had to have different length antennas for different frequencies. The transmitters all have the same antennas too. What's the explaination?
RE: Hen long Antennas
If you are talking about several different crystal sets, then the frequency shift is too small to bother with different length antennas.
The HL antenna / radio set-up is not the ideal set-up possable... it just works "good enough".
The ideal set-up is a 1/2 or 1/4 wavelength di-pole antenna tuned to the exact frequency. At 27mhz that's much too long to ride on a 1/16 scale tank.
2.4 ghz is short enough.
Antenna length isn't as big a deal with AM radios as opposed to FM radios....but like Pah stated the difference is so small it's not worth worrying about. I generally cutt the Metal antennas in half (or less) and have had no appreciable degredation on range(maybe 25%) but who drives their tank from over 100ft away...?
You're right ...The higher the frequency , the shorter the wavelenht ; the shorter the antenna ....
Heng Long has set for i/32 wavelengh for their antenna ( as per the amateur vertical antenna calculator on this site : www.csgnetwork.com/antennaevcalc.html
FL
ORIGINAL: DirtyBird69
So what your telling me as I can cut that long ugly antenna in half with no real issues? I'll cut that puppy tonight!!
