Tamiya Panth/Jagdpanther & Tiger roadwheel diameters needed
Could someone please tell me the diameter of the roadwheels on a Tamiya Tiger 1 and either a Tamiya Panther or Jagdpanther please?
Im after the size without the tires on.
Cheers,
Rik
Cheers,
Rik
RE: Tamiya Panth/Jagdpanther & Tiger roadwheel diameters needed
Rik, I don't have a metric caliper, so you'll have to convert. I took measurements at two places without the tire on - at the visible OD of the rim, and at the largest OD (the part that "centers" the rubber tire). The visible OD of the Tiger is 1.695" and for the Panther it is 1.825." At the largest OD, for the Tiger I it is 1.833" and for the Panther it is 1.969." -Mike
Woooooppppsss all I can say is it was a late night and the brain was shutting down CM is right
Nope, Rivetcounter was totally right, 800mm for the Tiger I and 850mm for the Panther.
Wheels of 850cm in diameter should be higher than the tank itself ...8.5m some 335 inches......
Uhu
Uhu
