Clark electronics TK20
#376
RE: Clark electronics TK20
ORIGINAL: mustclime
Thanks, I will look....In working with this board, has any one been able toseperate the sticks forhull and turret functions? In ir battleing not being able to turn the tank and turn the turret at the same time will be an issue, same with gun elevation and driving. With a tamiya tank able to do everything with the turret with one stick and everything with the hull with the other stick, guys with the clark board are just going to be easy kills up close.
I have all movement & steering on my left stick, while all turret controls are on my right stick. It was very easy for me to set up on my FlySky CT6B controller using the DigitalRadio program as I outlined in my post here on the forum before => http://www.rcuniverse.com/forum/fb.asp?m=11331522
The only difference in control I have now, from what I had explained in that post, was I moved the gun elevation to channel 5 & now use a servo for it. So if Tamiya owners, or any other RC tank owners, can easily kill me in an RC battle, it's just that my battle skill experience is seriously lacking, & not because of the control setup I have on the tank.
~ Craig ~
#377
The main problem I've come across with all these aftermarket battle systems (with exception of EL MOD or SLU, never tried'em) is they are set up for HL transmitters and controls.
The biggest hurdle is how to control elevation without the main gun or MG firing since like I said most of these are setup to work with the stick down revolving elevation unit
from HL. Has someone overcome this?
#378
ORIGINAL: TheBennyB
Besides, even though the "stick down revolving elevation", or what I'll call cycling gun elevation, is a HL "feature", the Clark board gives you control of the stock HL elevation motor to move it either way you want, up or down, whenever you want. You don't have to wait for a full cycle for the barrel elevation to change directions.
~ Craig ~
#379
ORIGINAL: B.A.D.A.S.S.Force
Read the post just before yours , as I mentioned, you can add servo elevation if you want it.
~ Craig ~
ORIGINAL: TheBennyB
~ Craig ~
#380
AZ
If you pop out the electronics on a servo, it works great as an electric motor. Hook up the power and negative leads and plug into the Clarke board and you have an instant servo (motor) controlled elevation. Smaller application then the HL cycling mess and much faster response. I tied a 22 ohm resistor to slow down the servo response. I'm going to try a Gear Servo which should move slower and have more torque as I think I choked the power down too much on the servo with the resistor (it struggles somewhat in raising the cannon).
tjs
tjs
#381
AB, CANADA
ORIGINAL: TheBennyB
Oh yea, forgot the clark had the servo elevation plug in. Now if YHR can get the Benedini to work for turret sounds as well as engine sounds we'll be in business.
Read the post just before yours [img][/img] , as I mentioned, you can add servo elevation if you want it.
Besides, even though the ''stick down revolving elevation'', or what I'll call cycling gun elevation, is a HL ''feature'', the Clark board gives you control of the stock HL elevation motor to move it either way you want, up or down, whenever you want. You don't have to wait for a full cycle for the barrel elevation to change directions.
~ Craig ~
ORIGINAL: TheBennyB
~ Craig ~
You can mate up a Benedini to a Clark board, and get the engines sounds, but you have to use all the other Clark sounds. Which are pretty good.
The DBC3/Benedini, with a HK T6A radio operates just like a Tamiya now. you just need to use channel five for Gun elevation, and Map the Benedini to play gun elevation sounds when you use that channel. Both of my latest rebuilds, the T-34 and the Sherman both have this function.
I also have my Clark board set up to operate like all my other tanks. You just need to play around with the servo assignment. The only caution is that there is no start sequence for this board. As soon as you turn it on it is ready for action. I damn near ran my KV1 right off the bench!!!.
#382
ORIGINAL: TheBennyB
Also, not entirely true regarding the elevation Benny, the Clark TK22 has servo elevation & servo recoil, while the TK20 boards only have servo recoil built into them.
To add servo elevation on a TK20 board you need to do what I did by hooking up a servo directly to the receiver itself, bypassing the board.
~ Craig ~
#384
ORIGINAL: tomhugill
I think benny just means hacking the servo so it acts as a motor.
~ Craig ~
#385
ORIGINAL: tsull
tjs
tjs
So if you take out the electronics from the servo, it just becomes a typical motor, meaning it just keeps turning in one direction according to polarity, without stopping at high & low peaks?
Then in essence, if I'm getting this right, it's just a better movement (by your experience as regards to response time) than the stock HL motor provides, & has a smaller footprint, but not really a servo like action anymore, so if you keep the stick in one direction it will also just cycle the barrel just as the HL stock system. Is this correct?
~ Craig ~
#387
AB, CANADA
I don't have much experience with servos at all, & never did a mod to any. The servos I installed in both my HL tanks to get recoil & elevation recently were the first I've ever held in my hands.
~ Craig ~
ORIGINAL: tsull
tjs
tjs
~ Craig ~
#388
Along with the rest of the sounds, I think the turret sounds are very good on the Clark boards, so I'm already in business with just an inexpensive Clark board.
~ Craig ~
ORIGINAL: TheBennyB
~ Craig ~
the ability to use a benedini for all sounds. For now I'll prob just go with the DBC3/benedini YHR set me up with and use servo's for recoil and elevation. Just gonna have to be careful on the amount of stick travel so the main gun and MG don't fire when I elevate/depress.
#389
AZ
I didn't remove the cog in the servo that I just hacked. I was using it to drive my elevation so I didn't want it to rotate fully like a motor. I don't know if it really makes a difference as the elevation has stops in it that restrict the movement of the servo motor. My first try was with a Tamiya gear set that I bought for $12. If you haven't played with one, they are fun to put together and work well. The problem was there was just enough slop in the gears and the torque was so strong that once it hit the elevation stops, it started tearing the gears apart.
tjs
tjs
#390
Well, I am throwing in the towel with clarks site.....that pretty much meansI am giving up trying to get their dam boards running in the e100. From what I can gather, their site takes so long to open,my cable/internet provider drops the connection asnot being there.
thanks for all the help guys, good luck with these.......
#391
well I did not burn up the card or the speaker....the hl volume knob cooked. I got another one from another project and used larger wires to cut resistance.....now the sound isgreat with my 2.5mm thickstyreen speaker box and a sony speaker I got from phill.....I have all the turret action on the left stick and all thehull action on the right stick.....thing still turns like a pig, I still have some issues with the settings with the transmitter.....
since I can not get onto the clark site, I need any info you guys can get on how to hook up the "real recoil" with a hs 81 servo...that and any info on setting up the turret....
#393
ORIGINAL: mustclime
~ Craig ~
#394
ORIGINAL: Rebellion13
Mustclime did you try using Firefox? I never have any problems using that browser.
Cheers
Wade
Cheers
Wade
#395
Mustclime it is your settings or your internet, My PC, Laptop, Phone and Playbook all load clarks site with a vareity of browsers.
Go into your security settings and lower them just to see if it actually loads the site
ORIGINAL: mustclime
I updated to Internet explorer 8 and AOL10.1......seems that the problem is my Internetprovider.....Iuse optium cable for it...the problem is how slow the server that Clark uses. It takes so long for the site to respond, that they cut the connection post that the siteis not there..........
Cheers
Wade
Cheers
Wade
#396
lol...I need to lower the security settings to read Clark? yea, thats a good idea......not!.....aol replied to my questions about not getting through to Clark by telling me that 10% world wide web identity theft out there is coming out ofthe wed service these guys are using......If its a choice between throwing 2 Clark boards in the trash or dealing with someone taking 2 loans out on my house because I lowered my security settings for some web site out of china.......guess those boards are toast.....my brother-in-law just spent over 8 grand to clear some overseas identity theft issues...the laws in this country make you the fall guy for someone stealing your identity, not the bank...think about it.
#397
ORIGINAL: mustclime
And I did think about it, so maybe you should too, because it sure doesn't seem like any other ISP services have been banning Clark Models website for any reason with all the other forum members from around the world that use different ISP services to access the site. So either everyone else on all the various tank forums who visited Clark's website over the last year all have very poor or lacking ISP security services, or your service is being overly restrictive without real reason to be that way. You do what you want concerning the boards, but I would get rid of AOL & find another ISP before I got rid of the Clark boards.
~ Craig ~
#398
Hey Scott, there's a screen cap off the clark site showing which plug the servo recoil goes intohttp://rctankregiment.com/rctankforum/download/file.php?id=5209
There's a link giving you the setup information you will need. If you need more info let me know and I'll knock up a PDF or something for you
Ps if that pictures not 100% clear it's the three pin port closest to the white socket the servo connects to.
