Feedback from speaker
Hi all, when I run my Tiger I get feedback thru the speaker. It's an HL Tiger with the DBU system. When I start it up it sounds fine, but as soon as I start moving it the noise starts. It's a high pitched whinethat all but drowns out the motor noise. Any ideas why? Or better yet what can I do to stop it?
Thanks for your help, Kevin
AB, CANADA
RE: Feedback from speaker
One thing that you might want to do is power the DBC from a different power source. I use the RX18 with the Benedini system, and discovered the newer RX18s are better, and then when I used a separate power supply to power the DBC the noice was reduced as well.
I posted a thread on this awhile ago. I'll try searching for it and post the link for you.
Here it is
[link=http://www.rcuniverse.com/forum/m_11204147/anchors_11204492/mpage_1/key_/anchor/tm.htm#11204492]DBC mods[/link]
Dan
Here it is
Dan
Hello
From reading the posts here I noticed that NO one has said that you should try noise filtering capacitors on the motors. Three non polarised capacitors are placed on each motor,Positve to motor case, Negative to motor case, Positive to Negative and Just for extra insurance motor case to battery ground. Brushed motors have contacts, when the motors are working, turning, they arc and produce high frequency which is usually picked up by near by speakers and they can even effect unshielded electronics. This is the Norm in any R.C boat for example.
George
George
The twin RX-18 mod. that I'm using to cancel the track recoil is also eliminating that feedback ; since the motors and the speaker are on 2 different boards...
A tank filter (i.e. capacitor inductor tunned filter) can be used on the speaker terminals to reduce the offending frequency(s).
If the whine is constant, this method should work well, if the whine changes pitch while running then much less effective.
Off-hand I would try a tank filter tunned to about 15kHz as this (to me) sounds very similar to whine from old CRT television X-ray power supplies.
This pic is the basics of a tank circuit. The values of the components L and C will determine the filtered frequency. The wiring is across the speaker terminals (where the V reference is shown).
The impedance of the speaker will also affect the tank circuit as well as the output circuit (i.e. amplifiler circuit), so a bit of experimentation would be needed to accurately tune the tank circuit.
