If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 24 of 24
  1. #1
    DirtyBird69's Avatar
    Join Date
    Nov 2010
    Easton, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HL Gearbox stand-offs??
    I heard some guys mention in the past that you can use motherboard stand-offs from a computer to replace the stripped out plastic ones molded into the HL chassis. was wondering If anyone could give me an update and as to what size i would need?....thinking of replacing mine just to add a bit more strength as I already have two that are split that have been repaired..
  2. #2
    Perry S.'s Avatar
    Join Date
    Jan 2007
    Clifton Park, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: HL Gearbox stand-offs??
    Those standoffs are a terrible weak link. I usually shave them off. Stack up a couple sheets of styrene and drill it though. Then you can bolt through the hull, spacer and gearbox. Pretty much a free mod if you have the styrene which we probably all do. Plus you end up with a bulletproof, non flexing, gearbox-hull combination that is reinforced by an additional 1/4" of plastic. So simple to do I don't know why you would want to stick with a standoff on the flimsy HL plastic hull.
    Hope this helps,
    Perry
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1812509   Click image for larger version.
  3. #3
    A N Z A C's Avatar
    Join Date
    Mar 2008
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    look for 6.0mm nylon PCB Stand Offs (same as used in computer motherboards etc)
    HL SdKfz 181 : HL PzKpfw III : HL Sd.Kfz.173 : HL Sd.Kfz.182 : HL KV-1
  4. #4
    Join Date
    Jul 2005
    Renton, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Perry S.
    Those standoffs are a terrible weak link. I usually shave them off. Stack up a couple sheets of styrene and drill it though. Then you can bolt through the hull, spacer and gearbox. Pretty much a free mod if you have the styrene which we probably all do. Plus you end up with a bulletproof, non flexing, gearbox-hull combination that is reinforced *by an additional 1/4'' of plastic. So simple to do I don't know why you would want to stick with a standoff on the flimsy HL plastic hull.
    Perry, that's a great solution, thanks! Even on the Asiatam hull with it's separate gearbox "plate" with sort of built-in standoffs, your idea can be used to solve the problem of the terrible screws provided, and will allow a good measure of clamping force without worrying about stripping a flimsy piece of metal.
    < http://www.rcuniverse.com/market/category.cfm?catID=178 Check the RCU classifieds! >
  5. #5
    YHR's Avatar
    Join Date
    Nov 2006
    Grande Prairie, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Perry S.
    Hope this helps,
    Perry
    Yes I kind of do the same thing. Bolt right through the bottom of the hull. You have four exposed bolt heads, but honestly how often does anyone look at the bottom of a tank. The result is rock solid.
    Stand offs can work well, but there is a lot more fussing with them to get everything lined up. This way here, you build up the floor, drop in the gears, mark, drill through, install hardware, done.
  6. #6
    Join Date
    Nov 2010
    Easton, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I agree, even though I "think" I got everything locked in tight right now, I might tear into it this winter when I have some free time and do the same thing...Gonna order the materials next week....fortunately my 2.0's came with one of those mounting plates which I can use as a pattern....think I will bond the layers(gonna buy a pack of .60" styrene sheets)with a thin coat of epoxy....makes you wonder if there might be a market if somebody could design a generic pattern based on the mato plates and simply have gearbox padsmachined out of one thick piece of styrene(lets just say 1cmthick for example)with all the holes in the proper locations. I would think the stand-off height, and hole locationswould be the same in all(or at least most)HLtanks...Think I might check into this a little....
    p.s.Being that I can't seem to convert in my head, I was wondering about how many sheets of .060 styreneI would need to make a pad roughly 1/2" thick? .060" what does that equate to roughly (1/8",1/16",1/32")? Should I go with .080"?
  7. #7
    Join Date
    Oct 2012
    london, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    here ya go , 8 x .060" + 1 x .020" or 6 x .080" + 1 x .025" equal 1/2" .
    Designed by computer , built by robot , assembled by chimp .
  8. #8
    Join Date
    Nov 2010
    Easton, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok ..thats what I needed to know..I figured roughly 8-9 pieces..
    ORIGINAL: blimp uk
  9. #9
    Bagheera's Avatar
    Join Date
    Apr 2009
    Peterborough, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't think much about the stand offs, not enough support. Stripped down the floor and put down styrene right to the battery box. Makes it a vary sturdy base for the gear boxes.
    Cheers
    Johnny
ID:	1813154   Click image for larger version.
ID:	1813155   Click image for larger version.
ID:	1813156   Click image for larger version.
ID:	1813157   Click image for larger version.
  10. #10
    Join Date
    Nov 2010
    Easton, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yup, I'm definatelty upgrading to a more solid base like yours...maybe even add a slab on the sides of the gearboxes like you did..very nice... Did you screw your gearboxes in through the bottom(please show a pic of the bottom with boxes installed)?
  11. #11
    Join Date
    May 2009
    Evans, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you rill the hull before placing the styrene, you'll have the exact hole locations of where the original standoffs were located.
    Jim
  12. #12
    Join Date
    Aug 2011
    Holmestrand, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry but what does "rill" mean ?
  13. #13
    Buckeye36's Avatar
    Join Date
    Apr 2010
    Egg Harbor Township, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Think it was a typo, drill
    Tam Tiger 1, Tam Sherman M4(105), Tam Jagdpanther G1
    ElMod Jagdpanther G2, ElMod KV-1E, ElMod StuG 40 G
  14. #14
    Join Date
    Aug 2011
    Holmestrand, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh right, stupid me
  15. #15
    Join Date
    May 2009
    Evans, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tisaksen
    Sorry but what does ''rill'' mean ?
    Yes, fat finger typo. I did mean drill. Boy forget to proof read once and you look like an idiote. LOL
    Jim
  16. #16
    Bagheera's Avatar
    Join Date
    Apr 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Dirtybird I just screwed the gear boxes to the styrene but the best way is to bolt it straight thru from the bottom of the hull.
    I've done this mod to 11 tanks so far. Me latest is the Panzer lV with a 3-1 gear box a Pzr lll is next.
    Cheers
    Johnny
    __________________________________________________ _____________
    HL Pershing x2, Tiger l, King Tiger, Panther G, Jagdpanther, Stug lll, Pzr lll x2. Pzr lV Tam Sherman and more to get !!
ID:	1814281   Click image for larger version.
ID:	1814282   Click image for larger version.
ID:	1814283   Click image for larger version.
  17. #17
    Join Date
    May 2009
    Evans, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jaws01
    Cheers
    Johnny
    Johnny,
    Great looking PZ IV. Where did you get the drivers from. They look like the later model drivers?
    Jim
  18. #18
    MAUS45's Avatar
    Join Date
    Jul 2008
    Old Hickory, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow, that rasies the drive sprockets up to the correct level on the Panzer IV. Very cool mod takes care of two things at the same time on the PZ IV!!!
    Tamiya Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 HL Jagdpanzer IV L/70, 1 R/C Armory 1/8 Tiger II
  19. #19
    Bagheera's Avatar
    Join Date
    Apr 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Pzr lV late drives and new close pin tracks are Mato. #MT011A. I e-mailed Matomart for them that's where I shop for all me tank parts.
    Changing and making parts is what I enjoy about the tanks.
    Johnny
  20. #20
    Join Date
    Aug 2011
    Holmestrand, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MAUS45
    ? I didn't know about this, are you saying the sprockets are at the wrong height on a stock HLPzIV ?
    ./t
  21. #21
    MAUS45's Avatar
    Join Date
    Jul 2008
    Old Hickory, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, they are a little low. Compare Jaws01 photo to this one and you will see the difference. I also included photos of a PZIV G and PZIV H/J to compare as well.
ID:	1821772   Click image for larger version.
ID:	1821773   Click image for larger version.
ID:	1821774   Click image for larger version.
  22. #22
    Join Date
    Aug 2011
    Holmestrand, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can't be much but it seems a bit off. Thanks for the picture comparison
  23. #23
    MAUS45's Avatar
    Join Date
    Jul 2008
    Old Hickory, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a photo from the Raiden site showing the Heng Long Panzer IV with the tracks on. It shows the reason the gear boxes need to be raised better than the previous photo with the tracks off.
ID:	1821858   Click image for larger version.
  24. #24
    Join Date
    Aug 2011
    Holmestrand, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Much better view, that's way off!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
