Walterson's Gearbox (Tiger 1) ?
Ok I am about to order an Asiatam lower hull and will be putting in the waltersons gearbox. I am thinking of getting the gearshaft supports also but they come in two sizes for the tiger 7.99mm and 8.08mm axle diameter. Are these needed/recommended and what size do I need for the waltersons? I am not sure what the diameter is of the axle shaft is. Thanks
Cheers,
Wade
Cheers,
Wade
RE: Walterson's Gearbox (Tiger 1) ?
I think I figured it out, I believe I need to get the ones with the bushings 8.08mm which would fit the mato/asiatam shafts which are basically the same as the waltersons.
Cheers,
Wade
Cheers,
Wade
