Tamiya Sherman question
My Feedback: (30)
NJ
The oil revervoirs on the shocks, are the metal ones much better? I have had to repair three of them so far. Also is there a recoil unit for the sherman available ? Moving along on the build, Got the top and turret to put together. Then start weathering.
Thanks for any info,
Bill
Bill
RE: Tamiya Sherman question
You can use a Pershing recoil unit in it if you use a different Tamyia board. Better yet use a servo recoil and save a lot of space in your turret.
I did not use the Tamyia suspension on mine, I used the Mato VVSS with no oil reservoirs.
Herman
Herman
If your sticking with the 105 I wouldn't worry about recoil. If your heart is set on it, then yes you'll have to getany otherMF unit that supports the recoil, and have to do some modelling to fit
a servo orrecoil unitbracket. As for the oil reservoirs, what do you mean repair? You've lost them completely by rubbing on something like the rest of us? Use the stock plastic ones and use
a rubber cement so they have some give.
ORIGINAL: Love To build
Bill
Bill
I think the epoxy sticks a little better to the metal versions than the styrene, but I wouldn't call them "better". They just fall in with the whole 'metal upgrade' deal.
If your building the kit with the stock Tamiya High Bustle turret, fitting a recoil in might be a tight fit. I believe using the Super Sherman board (so you still have the radial engine) you could then use a recoil with it.
It just depends on what Sherman you want to build.
HTH
~ Jeff
ORIGINAL: Rustytrax
Correct on the M51 having recoil but it doesn't have lights. So a choice is to be made there.
Neither do the German tanks so it's no big deal to me unless you drive in the dark.
~ Jeff
