JS-3 conversion kit for the KV-1
#76
Building is simple but instructions are not always clear, just some care if you want to build workable hinges off the resin ones, and I had to lower the external tank mounts to allow full turret rotation.
#79
Cheers. Actually did some google sifting and found this. Might help anyone else later on http://www.perthmilitarymodelling.co...-3barrels.html.
You don't mind if I hit you up with questions as I work through this? First time doing a conversion kit
