Reload this Page >
Hobby King ~ Turnigy 2.4 receivers?
Old 04-05-2013, 11:43 AM
Panther F
Panther F's Avatar
Default Hobby King ~ Turnigy 2.4 receivers?
Anyone have a saved link to those Turnigy 2.4 receivers?
These WILL work with the Futaba radio, right?
Tanks a lot!
~ Jeff
Old 04-05-2013, 12:30 PM
tomhugill
Default RE: Hobby King ~ Turnigy 2.4 receivers?
Are you talking about the orange rx's? If so as long as the tx is dsm2 you should be fine!
Old 04-05-2013, 12:57 PM
Strato50
Strato50's Avatar
They've been out of stock since forever >
Old 04-05-2013, 01:40 PM
Panther F
Panther F's Avatar
Thanks!
~ Jeff
Old 04-05-2013, 06:25 PM
Buckeye36
Buckeye36's Avatar
DSM2 is for Spektrum radios, they do have receivers for Futaba radios but they are FASST compatible (6EX, 7C, 8FG, etc..).
I'm not sure that they will work with the 4YF, 6J or 8J since they are FHSS radios.
Old 04-06-2013, 11:04 AM
bubbajoexx
bubbajoexx's Avatar
futaba FHSS radios. y6ou can only use futaba recievers if it where fast system then you can use the orange rx recievers
Old 04-06-2013, 02:19 PM
FreakyDude
FreakyDude's Avatar
Orange Futabas work only with futaba, fly sky makes some futaba compatible recievers as well but as far as I know there compatibility is very limited with different brands
Orange DSM, DSM2 and DSMX only work with Spectrum
Turnigy only works with Turnigy, Eurgle, Flysky and some Hobby King HK-T series recievers but be forewarned as you need to check the serial numbers to know for sure
Radio systems are way worse than tanks as far as uniformity goes
