Hobby King Transmitter problem
I have the HK-T6A V2 radio the problem I have is that I can’t get channels 5 and 6 to work, anyone had this problem
AB, CANADA
RE: Hobby King Transmitter problem
I have had three of these and they all have worked fine. There is some programming that needs to be done on the set up, but once done they have been great. My favorite radio now.
its a hobby King lol like the HL I have had pots wired backwards causing weak and fuzzy input signals. I suggest byou pop the back off and make sure the wires are connected both to the pots and the boards
ORIGINAL: rivetcounter
Both pots are the problem neither have ever worked, I have had the back off and all the wires and plugs are in place but it may be possible that the plugs are the wrong way around
YHR, I have programed the radio but still these two channels don’t work regardless of what I do
AB, CANADA
I will PM you a file that I use for my radio. You can upload this and see if it works. This will have steering and speed on the right stick, turret control on the left, and the proportional control of channels 5 & 6
