HL-Tiger I: How to remove the drive wheels
Hi guys,
how can you remove the drive wheels?
1. Remove the Tiger tracks
www.rcuniverse.com/forum/m_11502866/anchors_11502866/mpage_1/key_/anchor/tm.htm#11502866
Use a small screwdriver to lift the center lid.
The shape of srews can vary. Unscrew it and pull of the wheel.
Reassembling works the other way round.
PS:
If you have a version with a crossed-head screws, please replace them with similar hexagon socket screws. Those are easier to change and the heads last longer. The crossed-head ones easier make problems with the crossed slit by use it to often. If the crossed-head is damged, it is almost impossible to unscrew it.
Greetings
Birger
For a lot more help with your Heng Long Tiger I tank, follow the below link ...
HL-TIGER I, Basics, Failures and how to remove them.
PS:
Greetings
Birger
