M4A1E8 build
Old 06-01-2013, 05:06 AM
Panther F
Panther F's Avatar
Default RE: M4A1E8 build
I like the stowage placement (are those Nicks or did you make them) and your work on lowering the turret height really looks better that way.
I need to add some of that to my A1E8 someday.
~ Jeff
Old 06-01-2013, 05:12 AM
fynsdad
Cheers Jeff. The stowage is stuff that I've cast myself
The turret mod is a MUST for the Mato sherman, even if you do nothing else
Old 06-01-2013, 05:51 AM
ausf
ausf's Avatar
Superb.
Old 06-02-2013, 01:15 AM
9nene
9nene's Avatar
good job i like
Old 06-02-2013, 03:07 AM
Airbrushler
Airbrushler's Avatar
ORIGINAL: fynsdad
Got the stowage and weathering done. Just got a few details to finish off but she's about done, ready for her battle debut in 3 weeks
Nice Very Nice i want one now Great Job as always
Old 06-02-2013, 06:45 AM
  #31
bigfiver69
That is one fine looking Sherman!
Another amazing job... that's a pretty impressive shelf of tanks you must have!
Shep
Old 06-02-2013, 02:12 PM
  #32
fynsdad
ORIGINAL: bigfiver69
Shep
Cheers Shep, I'm afraid most of my builds live in the loft, I only have a select few on display[&o]
Although they did all get a weekend out a few weeks back at a model show we attended
Old 06-03-2013, 04:08 AM
  #33
bigfiver69
Pretty sweet array of armor there!
Old 06-04-2013, 11:25 AM
  #34
fynsdad
...and here's the next one in the stable. I had a complete Tamiya upper hull from the easy 8 build so thought I'd put it to good use
Old 06-04-2013, 11:38 AM
  #35
Panther F
Panther F's Avatar
He he... you're just as sick as I am with the Shermans!
(but you get more done)
~ Jeff
Old 06-04-2013, 11:40 AM
  #36
fynsdad
LOL You're right there Jeff, they're so bloody addictive
Old 06-04-2013, 11:46 AM
  #37
Panther F
Panther F's Avatar
ORIGINAL: fynsdad
YUP! Nice work.
~ Jeff
Old 06-05-2013, 01:21 PM
  #38
Robert Davies
ORIGINAL: fynsdad
What depth in mils do you remove from the base of the turret? - and out of curiosity, how did you cut it?
I've got the beginnings of an ersatz M1/early M50 on the blocks... I'm almost embarrassed to be living in the same country as Nigel, my work's so 'average'.
Old 06-05-2013, 02:02 PM
  #39
fynsdad
Its about 5mm that you need to remove. You're basically taking away the ring of plastic Mato have put there for clearance reasons. Once you take the turret apart it becomes quite obvious what needs removing
I use a razor saw, but you could use a hacksaw, dremel etc
Old 06-06-2013, 04:02 PM
  #40
Robert Davies
ORIGINAL: fynsdad
Excellent! Thanks for that. I don't have the parts yet - forgebear's out of them - So it's just to remove the insert to the moulding that Mato put in to jack up the turret?
I'll size the job up myself, but will use a razor saw if at all possible, for precision, and the cut that it leaves is almost finished, unlike say a dremel's.
I'm still in two (or more!) minds about either M1 or early M50, and those choices both subdivide into welded or plated cast hull... I'll see what the Mato top deck looks like when it arrives...
Thanks again.
-Rob
Old 06-06-2013, 09:33 PM
  #41
fynsdad
LOL I had the last Mato upper that Dave had, sorry
The Mato top is good, the lightguards/lifting eyes are a bit overscale and could do with changing, the barrel/mantlet are a bit iffy and the turret height are the only real issues
Old 06-06-2013, 09:57 PM
  #42
Airbrushler
ORIGINAL: fynsdad
Shep
i love all your builds you do amazing work
Old 06-07-2013, 03:50 AM
  #43
Robert Davies
ORIGINAL: fynsdad
I see...
