HL.KV-1 Real recoil modding & using slip ring for 360 rotation by SUGO
Hi everyone,
Here are photos showing "how to" modify the HL KV-1S standard recoil to be a real recoil.....by SUGO.
Start with bringing a standard HL recoil mechanism and take all the stuffs off.
RE: HL.KV-1 Real recoil modding & using slip ring for 360 rotation by SUGO
Glue the servo base plate to the casing and then install the servo.
See the work in the turret....
Note: There is a slipring using for turret full rotation too.
And the lower hull... metal lower hull with torsion bars, 4:1 gears, 480 motors.
Great idea!!! I like the concept that: Instead of reinventing the wheel; you modify something, that is already there; to fit your needs....
Next is the using of a slip ring for turret 360 degree rotation.
Thank you all of you....strmnd54, philipat,ausf
We made use of simple things with low cost but it's fun.
