Clark Board TK22 demo sounds out there???
RE: Clark Board TK22 demo sounds out there???
I have my KT herehttp://www.youtube.com/watch?v=hO61GufWNqQ if that isn't good enough for you let me know, I am just putting a Tiger and Jagdpanther together and I could do a video for you.
there are lots of vid's on you tube of the Clark TK22 as well.
ORIGINAL: T Skaz
Are there any demo sounds of the Clark TK22 board for TIGER1 that I could listen to before I purchase?
Would you say it sounds better than the SLU or Benedini boards. A gentleman on this forum sight name Dan sells a complete board...forgot which one but not a clark.
you have to talk to YHR about it i like the stuff he does with it he mixes it with the DBC3
http://www.rcuniverse.com/forum/m_11561168/tm.htm
hi T Skaz
as i've not saw any reference to another alternative that exists, i will put it here: Beier USM-HL
if your tank's electronics is the RX18, you can install directly and with no any soldering this sound card
http://www.beier-electronic.de/modellbau/index.php
you will keep all the guts of your tank, but a change of speaker is advised, i use the visaton FRS7 (8 ohms) in both my tanks
all the sounds are customizable, she cames with several profiles, but i make my own. If you want to take a look:
Tiger profile
http://www.youtube.com/watch?v=JMo-3IREYDs
Königtiger profile
http://www.youtube.com/watch?v=K4enpzKdZAU
best regards
[/b]
Tiger profile
Königtiger profile
best regards
[/b]
AB, CANADA
You can check out my website for demos and cost of the dbc3 and Benedini
[link=http://battlearmorrc.weebly.com/]Battle Armor RC[/link]
Cheers
Cheers
ORIGINAL: T Skaz
What do you know about the Benedini board? Does it sound good? Do you know how much $$$$ ?
If you plan on having more than one HL tank, you can mount the DBC/Benedini/speaker on a removable card and change tank to tank if you wish.
Dan will be able to get you the prices and all the info you need as well as support before and after if you decide to go with one.
Skaz
I would say the Benedini sounds better but look at the cost of the board as well, The Beier sounds equivalent to the Benedini but again the cost of that sound car is pretty high as well.
The Clark TK boards are equivalent to the SLU with regard to the quality of sound. Only 2 sounds the SLU plays that Clark doesn't and that is track squeaks and you can have the panzerlied played on the SLU.
There is no soldering, cutting etc to install the Clark board, You just plug everything in and it works. There are 2 modifications you can make though
1) wire mod to the elevation so you have proportional elevation of the gun- reasonably skilled person should be able to do this in less than 15 or 20 minutes though
2) Servo recoil - little bit more mechanical knowledge here but you can modify the gun to use a servo for the recoil. This is a very realistic thing. estimated time - heavily depends on skill of modeller but an inexperienced person it might be as much as 3 or 4 hours.
I build the parts outside oif the tank then just install them, I can do the recoil in about 30 or 40 minutes but I have done oodles of them.
What I know about the benedini is that it is part of the DBC system although you can hook it up to the Clark board and it works very very well. The Clark has its own amplifier and you can use that to run the enginbe sounds into one speaker and the cannon and turret sounds into another speaker.
When done properly you can actually rev the tanks motor, there is a post by reymanuel on how to do it here somewhere.
ORIGINAL: T Skaz
Hi Jussek,
I also have a Beier, do you know how to hook it to HL's new 2.4g control board? CN8( receiver board port ) does not exist on new 2.4G board.
Regards,
Clark
Regards,
Clark
Thanks for that in depth explanation. It was vary helpful. I am leaning on the Clark....less $$. Sounds easy except for going beyond plug in. All that other stuff you mentioned at the end sounds complicated. I'm real handy but don't want to screw it up and cost me more bucks. If I tare it down I would mostly like go the distance.
Here's a [link=http://www.youtube.com/watch?feature=player_embedded&v=aiv462G76Rw]youtube link[/link] that shows the battle sounds for a Clark TK-22 German board, which I believe is the Tiger I (even though it's in a Pzkw4, configured as a heavy tank). The Clark's a great board (especially the servo recoil with sound/flash sync & track recoil), but I'd love to get YHR's DBC3/Benedini set. His Panther sounds great!
If your worried about the recoil let me know what tank you have and I'll work out a cost for the parts to do it. I have all the HL tanks in stock so I can pre-fit the parts. Really it is not hard to do, just a bit time consuming but it is like I said the recoil is an option, you can wire any recoil system to work with the Clark board. I have step by step guides done with exception to the recoil. I am working on that one but it is slow going when you have other things that need to get done.
ORIGINAL: T Skaz
hello Clark
i'm afraid that if the model is the USM-HL it would not work with the 2.4GHz electronics (the USM-RC will)
this is a link to the beier website that deals with this question, it's in german, but chrome translation works 'enough' to understand ;-)
http://www.beier-electronic.de/model...php?f=17&t=416
but maybe it would be better to ask beier directly
best regards
best regards
Hi Jussek,
Sorry, I did no make it clear. my question is that HL has introduced a new 2.4G control board on thier leopard 2A6. we know USM-HL or DBC3 send command to CN8 on RX-18 to control it, but this new control board has no CN8(receiver board input), do you know how to hook USM-HL to new control board? I thought you're familiar with berier and I just want to hook berier to HL Leopard 2a6 and sell it.
I'll also try german berier forum or contact berier directly.
Regards,
Clark
Regards,
Clark
Also the IBU2 board is now another alternative to all above mentioned systems.
It's a full option board (meaning it completely replaces the inside electronics) and interfaces with a common receiver (4 ch required).
-Sounds can be self-customized and come on a microSD card (most common sets already supplied).
- Track squeaking sound randomly played
-3W audio amplifier on-board (8W optional).
-Fully plug and play on any HL-style tank.
-Ring of leds for HL receiver apple supplied.
-Li-po support with voltage level monitoring.
-Bidirectional barrel elevation (no hardware modification required).
-HL, servo or Tamiya barrel recoil (no hardware modification required).
-Power consumption is highly optimized, even uses to regenerate power to the batteries during coasting and braking.
More on: [link=http://ibu2.forumattivo.com/f4-english-forum]IBU2 Portal[/link]
Don't forget this, if you are looking for state-of-the-art Tiger I sound which no programmable sound card can achieve.
[youtube]http://www.youtube.com/watch?v=AZolbkMZLYs[/youtube]
[youtube]http://www.youtube.com/watch?v=3UXqCoon78g[/youtube]
ORIGINAL: borealis
AB, CANADA
ORIGINAL: clarkmodel
???Don't forget this, if you are looking for state-of-the-art Tiger I sound which no programmable sound card can achieve.
I think the Benedini has been achieving this for years, as you can adjust the start voltage and have the tank rev up with out the motors breaking free, so as far as I know the Benedini has this covered?
if listen carefully, you will find the engine rev, engin in different rpm, gear shift sounds are much close to real tiger, and in production version, different track squeaking sound will be synchronized to real track speed and randomly played
Regards,
Clark
Regards,
Clark
