My HL Leo build....
#51
Wow mcm, it's a fantasic build. The primer coat brings out the detail
The elevation in the gun tube after firing is for the spent shell ejection, the Tamis do it as part of the DMD and MF units
I'm looking forward to your turret build.....
#52
Thanks! I am making progress on the turret. I have the rear done. I bent up some of the tubular rails on the top side. I dont have much time during the week to work on it. I need to get some .040 hex rod to make all the bolt heads. Im looking forward to that!
I should get the mesh for the baskets today or tomorrow. I ordered Aber S18 drilled plate from a supplier in Canada(Air Connection).
I have the correct smoke launchers from AFV model. They are resin pieces that need alot of trimming and finish work. I thought they would have the chains for the caps but they dont. I have some chain that might work although it might be slightly larger then what its suppose to be. Atleast I dont have to scratch build the entire units.
Stay tuned...
Stay tuned...
#53
#59
don't know if my question went thru but I have the metal track too but put the plastic black one's back on because silver didn't look good with a dark green cam leopard..lol..do you or would you paint the metal track? Id like to but don't want to screw it up. Idea's?
#64
I have to totally regroup on this. All the old pictures are gone so I will upload some current status pictures. I might need some help figureing out how some of the internals were assembled. All the screws and small parts are in a bowl and I forget whats what..lol
Picking up where I left off, A good chunk of the turret construction is done. I need to finish some of the top side and detail. Then I can prime and see where I stand. Probably have to add some filler here and there...
#67
I did manage to paint the tracks. Mainly just did the insides and sides. The outsides are going to get hammered up anyway and let natural wear take its course from here. Now for more filler, sanding and then detail items like bolt heads, grab bars, levers on the top side boxes, etc. After I am satisfied, a quick final coat of primer and the camo. Im not a rivet counter so some of the very tiny stuff that my fat fingers have a hard time with might not get done but I try for the effect. It is starting to look good..I must say...lol
#74
