LEOPARD 1A4 Tank Scratch built 1/12 scale
Reply
Old 03-03-2014, 01:47 PM
Hein SA
Hein SA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default LEOPARD 1A4 Tank Scratch built 1/12 scale
Hello everyone
Here you will find the whole building process of my Leopard RC tank, where it began as an idea, to sheets of plywood, to a fully functional R/C tank. It took me 6 months to complete, working on it whenever I got the time. I am not adding a lot of comments, I let the photos explain themselves. Feel free to comment and ask questions!!
Here it is all finished Weight : 12.5 kg scale : 1/12
The real deal.
Where I got most of my measurements.(An old war machine magazine)
Drawing everything on the back of an old Ron Belling poster scale 1:1
The rear drive-train of the tank. Two 12V cordless drill motors, each with their planetary gearbox. Angle grinder gears to deliver the power through the 10mm stainless shafts to the drive sprockets.
Steel swing-arms custom bent at an engineering shop.
Plastic track pads, and chain track assembly. The 2 tracks consist out of 590 parts, not counting the chain.
Cutting my wheels on a lathe, it was a lot of fun but after wheel nr. 10 I just wanted to finish.
The end result. x2 ball bearings for each wheel, press fitted into the bearing cavity.
Turret and upper hull, all constructed out of model grade plywood 5mm and 3mm. I love working with model grade ply, its an awesome material.
Gun elevation and turret rotation achieved with standard servos ( turret rotation servos was modified to rotate continuously).
Adding some detail with wire, dowels, pins and thin ply.
The 2 drill speed controllers with reverse, operated with servos. It took me a while to figure out how to build them.
​Everything is coming together...
​Suspension working nicely.
Test layer of paint added.
Hand painted decals
The Goldilocks size RC tank...
Enjoying the weathering process
Thanks for watching, View the YouTube video below
http://www.youtube.com/watch?v=CYOaO4j3YYo http://www.youtube.com/watch?v=g-4CtYga8n8
ID:	1974498   Click image for larger version
ID:	1974501   Click image for larger version
ID:	1974502   Click image for larger version
ID:	1974504   Click image for larger version
ID:	1974507   Click image for larger version
ID:	1974508   Click image for larger version
ID:	1974509   Click image for larger version
ID:	1974511   Click image for larger version
ID:	1974512   Click image for larger version
ID:	1974513   Click image for larger version
ID:	1974514   Click image for larger version
ID:	1974515   Click image for larger version
ID:	1974516   Click image for larger version
ID:	1974517   Click image for larger version
ID:	1974519   Click image for larger version
ID:	1974520   Click image for larger version
ID:	1974521   Click image for larger version
ID:	1974522   Click image for larger version
ID:	1974523   Click image for larger version
ID:	1974524   Click image for larger version
ID:	1974525   Click image for larger version
ID:	1974527   Click image for larger version
ID:	1974528   Click image for larger version
ID:	1974529   Click image for larger version
ID:	1974530   Click image for larger version
ID:	1974535   Click image for larger version
ID:	1974537   Click image for larger version
ID:	1974538   Click image for larger version
ID:	1974540   Click image for larger version
ID:	1974541   Click image for larger version
ID:	1974542   Click image for larger version
Hein SA is offline
Old 03-03-2014, 06:20 PM
YHR
YHR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Tank. You need a sound system for that baby,
YHR is offline
Old 03-03-2014, 09:37 PM
Hein SA
Hein SA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dan.
Yes, I tend to agree with you on that one.
Hein SA is offline
Old 03-04-2014, 12:57 AM
Panther F
Panther F's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice work! I love the size and it's very true to scale too.
Wish I had one THIS large!
Jeff
Panther F is offline
Old 03-04-2014, 07:48 AM
Hein SA
Hein SA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jeff,
Hehe Yes, I tried to build everything exactly to scale. But I could have added more detail to the wheels and sprockets. Maybe the next holidays...
Hein SA is offline
Old 03-04-2014, 04:28 PM
Panther G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Outstanding job you have done there sir. Very nice tank to model also.
Panther G is offline
Old 03-05-2014, 07:21 AM
Hein SA
Hein SA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Panther G
Hein SA is offline
Old 03-05-2014, 01:12 PM
wsn123
wsn123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice tank - what electronics is inside?
wsn123 is online now
Old 03-05-2014, 01:51 PM
Hein SA
Hein SA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello wsn123
The whole tank is completely controlled with only 4 servos. One to operate the turret elevation, one modified servo for the turret rotation (rotates continuously) and two for the speed controllers. The two speed controllers in the tank are the drill trigger speed controllers which I modified to be operated with servos. I took out the stiff coil spring in the trigger speed controllers and designed a cam mechanism which engages forward and reverse. All cordless drills have this forward and reverse switch, all it does is reverse the direction in which the current flows. And that is about it, I only use 4 channels, and the receiver and battery pack is housed in the turret for easy access. The two servo cables coming from the two speed controllers just go through the center shaft of the turret to the receiver.
Hein SA is offline
Contact Us Archive Advertising Cookie Policy
