metal track come alongs.
i managed to break the track apart but trying to reconnection i can't get the track close enough to slide a the pin in.
are there come alongs like you use one actual tank tracks available or whats the best way to reconnect?
It's easier to connect the links over the drive sprocket, it helps align them. If you put the suspension under weight, you'll get more room since there will be less tension. If you have adjusters installed, loosen them.
You may have too much tension on the tracks, they should have enough play to easily remove and install pins.
If you have a spare pin, you can install it in the end of a dowel (I use a small screwdriver handle) to make a pin pushing tool.
