Spektrum Dx6i for firing machine gun and main gun using the switches.
CA
I recently ordered rhe DX6i to be used with my Tamiya M26 Pershing. I was hoping I could get some people who are using this radio to post there set ups. I would like to use the gear switch to fire the machine gun and the elev D/R switch for the main gun. I did search google and found this http://www.hobbyhavoc.com/oldhavoc/i...p?topic=1130.0
I am still waiting for a receiver to come in the mail to test it out.
I appreciate your help.
I assume tamiya uses the stick in some position to fire- its possible, I think ausf has his setup like that, but I don't remember which model spektrum he uses. I use a dx7s and set mine up to the gear switch in around half an hour while I was at danville.
Here is my setup, although I am using a clark board so the position of the stick may vary (and yes I know the screen is really dirty)
Anything obstructed by the glare was in the default position
Assuming you will use the Tamiya set up for the Tx (turret and throttle on LS, steering and elevation on RS), you just have to mix the gear channel (down) with 100% up elevator for the MG. You can add a servo in the gear slot on the Rx and animate the gun. Add a Turnigy chip and it's even better.
I have the main gun firing with the throttle cut, but that's a hard wire solution, not mixing. I don't think you can use the DR switch for the gun, possibly flaps (aux) since you can mix that to 100% down elevator.
You'll also have to play with travel adjustments to overcome Tamiya's need for trim work to select what you want to fire.
CA
Thanks guys. The more info the better. This is my first computer radio (TX) and allot of the terminology is over my head. Once I get my receiver (Tuesday) I will start working on it. Right now the tank is apart waiting for the new receiver. I do plan on using the standard tamiya set up. Left stick turret, right stick movement. The canon can be on any switch as long as it works.
That's an important designation because you can't mix the gear or flap switch to the throttle (LS on DX6i). Another point is while the MG doesn't really matter what switch it is, you don't want to be fumbling around to fire the main gun. Mixing to a switch isn't the best idea, especially one on the same side of the throttle. A switch will take your hand off the stick to move it on and then off, you might as well leave the Tamiya function of quick movement up. Most guys install a momentary push button to fire the cannon and locate it where it can be fired with a finger while still holding the stick. The DX6i conveniently has a momentary button right above the right stick (throttle cut) but you'll need to do some soldering which will kill the warranty. Of course it also kills the throttle cut if you ever plan on flying AC or helis.
The DAK club website has some info about programming the Dx6. Check out the downloads on the right-hand side of the page.
http://www.desertarmor.com/DAK_RADIO...Room_2011.html
I made it 2 years ago with spektrum dx6i and tamiya tiger so it is possible. I made something with mixing chanels.
http://youtu.be/l9nH1UhZCcU
CA
CA
Thank you Sir!
CA
The standard Tamiya is based on AC, it's LS: turret rotation, with throttle up and down. RS: steering with elevation up and down.
Thanks I was originally using a Futaba 4Y-F 2.4ghz and followed the direction in the build manual channel 1 to plug 1 and so on. I assume since this is for airplanes it is different. I defiantly want the main gun and machine gun on a switch. I'll try the pdf guide for the old DX6 that was provided by Ksoc and that should get me on the right track.
CA
CA
Canon gun works perfectly Mix 1 Gear -> Elev ACT. Rate D, SW on, U+125% trim INH
I cant get the machine gun to fire. Mix 2 Rudd -> Thro ACT. Rate D SW On, U + 125% trim INH
What am I doing wrong?
Also how do I turn the lights on? and get the tank out of idle mode?
I did recalibrate the DMD
To get the Pershing to move you have to disconnect the lockout function every time you start it up after shutdown. While tank is on and running put full reverse on throttle and release it. The tank should now react to normal stick controls. You must remember to do that when starting up from a shutdown every time.
Herman
Herman
Herman
Herman
CA
This is most likely why I couldn't find any set up info on the web. No one can do it without turning it into a nightmare. It was designed to work the way it works so why try and force it to do what it's not designed to do.
The main reason I use a DX6i is because I have other RC besides tanks where a 6 channel is needed.
It does allow for some cool customization but it comes at a cost in terms of frustration. It's really hard to get help with it because there are so many variables in terms of dual rates, sub trims, etc, it's nearly impossible to work unless we are in the same room and even then there could be something stupidly simple that was overlooked.
For me, it's also a heck of a lot easier to travel with one Tx as opposed to one for each tank. I have kids, so I use Futabas for 3 Tamiyas and control the rest (Tamiya, Losi, Xion) with the DX6i so I can have 4 people battling at the same time. If it was just me, I'd go exclusively DX6.
Hooking up the JS-2 (or Pershing) to start up would just mean using the stick like you would with the Futaba: trim down, stick down on throttle. On the DX6i, you might have to add some down throttle travel instead of trim. You could assign that to the aux switch by mixing full down throttle, but I wouldn't recommend it because an inadvertent hit of the switch would give you full reverse.
I own a Tamiya KV-1 with the DX6i and for firing gun, MG and unlock the movement i've done the SET of the DMD with the travel adjusted to 80% on the cannon elevation up&down and on the throttle reverse. When the SET is done i put the travel to 100% again on all channels so for firing and moving the tank on start up it's enough to put the sitck in full down or up. So no need of mixing functions etc. Just give a try
Personally i think the computer radios are just way over kill for a Tamiya tank. All you really need is the 4 channels and any analog radio that you can solder a momentary switch to the left or right lever. |It is that simple. Tamiya electronics just dont have that many functions to need a computer radio. If you want to use the same radio for multiple tanks just buy receivers and bind them to the radio. i guess if you plan on adding something to the system the you may need more radio but i just don't seem the need with a Tamiya tank. Only the Leo 2A6 has more functions than the rest and those are only lights.
