Dual motor drivers: outer track speed
Hi:
When turning, do dual motor drivers just reduce the speed of the inner track or the speed of the outer track is increased at the same time, in order to keep up with the vehicle's speed during the turn?
I'm writing a program for a microcontroller for that purpose (dual motor driver).
Hi:
The Tamiya Leopard (DMD/T-07) is the exception where one motor is a dedicated drive and a second dedicated turn motor. The turn motor increases drive side and reduces lag side by equal proportion. This is all done by mechanics (differential transmission) so technically there is no electronic turn algorithm for turning.
Well, I altered the program and now the outer track speeds up while the inner one slows down, it seems to be more realistic. Very closely as Dimension Engineering's Sabertooth 2x5 RC works.
One other thing is adding a brake to the inner track. I found the rx-18 couldn't do tight turns on grass because the inner track isn't breaked so the resistance of the grass will pull it around.
This is a few years ago so they may have changed the design. I'm not talking about pivoting with super spin, I mean turns with one track running and the other still! If hl have sorted I that's off to em!
