Help!!! Just got new all metal Taigen Tiger 1 and the lights just flash...
Hey Paul,
Glad you got everything worked out. Like I said the first time I posted to this thread, No worries, Erik's the best and he'll take care of ya.
Do you have the super smoker installed and operating? How did you do it? Wired directly to the battery with an on/off switch, or is it plugged into the rx? If it is working, any chance you could post a video?
I have the exact same tank(s) (I picked up a late IR to go with the early airsoft, both full metal). Did you get 3 to 1 or 4 to 1 gearboxes? I just put brass trannies in the full metal early, and I can't believe the difference. If those gomers ever quit jerkin' our boy around and send him some more brass gearboxes I'll be picking up at least a couple. Now that I've tried them I won't be satisfied til I have brass in at least all my heavy tanks. I can't wait to get a set in my Jadgpanther. My Panzer III and IV run pretty good with steel, and I have brass in the mato all metal PIII, but that's a very heavy little tank. So, brass for the light tanks would be nice, but it will have to wait. If only I could remember where I put that winning powerball ticket!!
Hey Paul,
Hey, do you notice a big difference between the brass and steel? if, so what?
maxu52,
I wired up the Super Smoker II as per the instructions that came with it under the heading "Instructions for El-Mod/Tamiya and other non-direct plug in devices"
In addition I wired the battery connection throught the on-off tank switch - that way if you turn off the tank - the smoker is turned off too.
The only problem I have with the Super Smoker is that it doesn't smoke mutch, and I don't know why.
I have the 4 to 1 steel gear boxes (I think) and I can't compare them to the standard gear boxes because I never used them - just the steel one's.
maxu52,
Also yes, the brass will be making a comeback shortly. I ordered a lot this time of the short and long shaft brass gearboxes and will be showing more on them shortly. They are by far my favorite gearboxes, I really like being able to swap gear ratios in the field in just a few minutes. Sometimes it is nice to have a bit more speed when playing around and lower ratio for battles and RP.
Hey Paul,
Thanks for the update. I noticed the same thing with my last smoker when I wired it straight to the battery - no smoke! I've been working on HL units to improve them, and I'm using Norm's method with the mini fan. I'm also experimenting with smoke fluid, using glycerin and distilled water. If I ever get it right I'll be sure to post the results.
Welchgc,
The biggest difference I can see between brass and steel is that the brass roll much easier and are quieter. I really like the way they roll. If you're at full speed and cut power the tank will actually coast a couple feet. That's pretty good, especially with a little tank like a PIII.
Welchgc,
#31
#32
I've been using baby oil in my smoke units for the last couple of years...It's cheap, available everywhere; and doesn't leave as much liquid residues as other smoke fluids I tested ( Glycerin and fog juice)...
The power used for the heater element of most smoke units varies between 3 and 5 Watts and doesn't generate enough heat to evaporate water; thus leaving more liquid residues from smoke fluid using water in their mix...
Here's an acoustic smoker running on baby oil....http://youtu.be/B99loI_QlOs?list=UUo...Z1uGnVnrbH3GxQ
#34
#35
#36
All brand of baby oil are pretty much the same: It's mineral oil with added aloes, perfume and vitamin E ....
The smoke unit in my tank is the prototype of an " acoustic smoker" where the pumping of the smoke is done by a speaker instead of a piston or fan...
I'm still working to improve the design and should be able to post some results soon....
#37
That's truly awesome. I can't wait. Like something you hear about at MIT or something. :-) I never would've thought of that, but it does make perfect sense. I'll be watching with great curiosity, and until then I'll get some baby oil tomorrow. I have the resistor installed and the minifan on, I'm just not getting the thickness of smoke I'm after. I noticed if I hold the tip of a lit cigarette over the fan I get EXactly the effect I want, so I figure better smoke will help. The large diameter of the pipes on the Jagdpanther probably don't help much either. I'll be messin' around with it tomorrow, and I'll try to get some video so you can see for yourself.
#38
Well, a day late ... I got the baby oil and shot a little video, mainly so Norm can see what I've done with his help so far (thanks again, Norm, these resistors really made the difference). This was pretty easy to do, and I like the results. Does anyone have any good tricks for reducing the noise on a HL smoker?
[h=3]100 2347 mini fan upgrade for HL smoke unit[/h]
#39
#40
Looking at the video, I can see that you put the resistor at the same position where the original heater element was...Turn the cover a 180 degrees in order to have the resistor in the air flow between the piston and the exhausts. This should increase the smoke output...
