Reload this Page >
Tiger 1 (Early, Middle or Late...)
Old 08-30-2014, 09:51 AM
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Jim you will need BUTTON HOLE THREAD attached to a weight and do keep your feet clear as the thread will wear out and the weight hurts! Me I use a step drill or using a pin vise I make a hole then insert an x-acto keyhole saw blade and then finish off with a file. The reason you should not use NYLON thread is that as it gets warm it will melt. shaun
Old 08-30-2014, 11:48 AM
Augustus1967
Augustus1967's Avatar
Yes Sir,
I've read about the Thread Method, Pin Vise and Mini Saw...
The method that I want to try first is the Step Drill...
To that end, I picked up a two bit set from Harbor Freight for $18 .00.
On a different note, yesterday I got a possible line on a couple Plastic Uppers and a Turret...
We'll keep our fingers crossed...
Did make some progress on the Early Taigen Hull last night.
Shot Primer on the exterior, along with a bunch of small parts and a set of plastic tracks.
Have quite a bit more to prime, but ran outta paint.
The plastic tracks are bound for return to the Plastic Tiger.
Plan to strip most of the Metal parts off it for use on the Taigen Hulls...
I'll post a photo or two later this evening...
-gus
Old 08-30-2014, 12:10 PM
jarndice
I love saving money, I am a very strange fellow? When I need to replace my Primer I go to the nearest AUTO PARTS dealer and buy a 500ml rattle can and change the nozzle for one from a can of model paint, more than half price and just as good. shaun
Old 08-30-2014, 01:16 PM
1sgt
Originally Posted by Augustus1967
Yes Sir,
-gus
Not too sure what a step drill is. I kinda have an idea, do you have a pic??
Jim
Old 08-30-2014, 01:30 PM
jarndice
GUS when using a STEP DRILL in plastic don't push too hard as the plastic will deform as it heats up. shaun
Old 08-30-2014, 05:02 PM
  #31
Augustus1967
Jim
Hello Jim,
having trouble saving an image down from Harbor Freight for some reason...
but here is a link to the set I picked up:
http://t.harborfreight.com/2-piece-t...lls-96275.html
Regards,
-gus
Old 08-30-2014, 05:06 PM
  #32
Augustus1967
Hi Jarndice,
Yes Sir, I hear ya...
I have read similar information on the thread from whence I borrowed the idea...
-gus
Old 08-30-2014, 05:19 PM
  #33
Augustus1967
Here are a couple photos:
Using Rust-Oleum Flat Red Primer and Flat White Primer...
The Sponson Box is a replacement for a damaged box on my KV1... Thank You Artistic Hobbies!
-gus
ID:	2027226   Click image for larger version
ID:	2027227   Click image for larger version
ID:	2027229   Click image for larger version
ID:	2027232   Click image for larger version
ID:	2027233   Click image for larger version
Old 08-30-2014, 05:31 PM
  #34
Augustus1967
I'd shot the set of Early Road Wheels with Vallejo Flat Red Primer...
But I must have done something wrong, as it peels off when I wipe my finger across the painted surface.
The Rust-Oleum seems to have stuck pretty good... On this batch of parts.
And as was stated earlier it's a Heck of a deal at $5.00 a can...
Though I may wind up transferring it from the Spray Can to another container,
so I can Shoot It through my Airbrush. I am not liking the Waste and lack of control when spraying
it from the can...
-gus
Old 08-30-2014, 05:44 PM
  #35
jarndice
GUS in an early part of this your latest novel I noticed you were thinking of using an early model CUPOLA, a word if you do not already know, HENG LONG, TORRO, and TAIGEN all mounted the CUPOLA in the wrong position ( it should be with the hatch hinge at the 20 minutes to 8 when looking from the front with the vision slit facing straight forward) THAT IS NOT THE PROBLEM, what is the problem is that the CUPOLA comes with a ridge on the inside that fits into a slot on the turret roof where the cupola sits, so you have to grind that ridge off the inside of the cupola to allow you to fit the CUPOLA in the correct position, shaun
Old 08-30-2014, 07:43 PM
  #36
Augustus1967
Haha...
Yes Sir... At least one Early Turret and One Late...
Most likely reuse the plastic Early cupola on the Plastic Tiger...
Heck man, I'm just trying to do my part in adding another thread to the Inter Web...
And if someone can have a laugh or learn something, including me, mores the better...
-gus
