Why doesn't IMEX have a Sherman?
I wouldn't mind a Ram Mk. II, or consider a Firefly a European tank
For me it's this: I LOVE German and Russian tanks and I suppose that it's representative of demand BUT I am also wanting an Axis/Allies balance because, just like World of Tanks, it becomes silly sometimes to always have German tanks fighting each other. :P So I guess my point is, how about levelling the grounds a bit and consider diversity more than just straight up demand? I think a Sherman and its variants (I vote for the Easy 8 too but I'll take any) is a singular exception in that it is so present in the theater in its time.
New molds won't go amiss. My only problem with the Taigan Tiger was it follows the HL pattern for joining the upper to the lower meaning there can be a gap where they meet that sometimes needs to be screwed down. This in turn can warp the top.
I am a bit confused here, our Tiger 1 is held down by a latch system...? Our metal tanks are secured through latch systems instead of screws, it is a lot easier for the end user to access the internals. Do you mean the side fenders where you screw from beneath?
It sounds like you may need some stress bars. The new Tiger 1 tanks have the front bar already installed. Is this something you would be interested in?
For my own tanks I usually use two of them, one in front and one in the middle. This makes it a ton more stiff and picks up the fenders a bit. PM me if you need one and we can talk.
#32
Well IF we did do one, I would think it wouldn't be that hard to make a few different versions... except for the Jumbo. If I remember correctly that is a whole new tank as far as tooling and such would go. We would have to see how the initial release went first and see how much demand is there. Then we could plan something like the Tiger where we have a few different versions. I have to tell you guys though... In order of requests it goes: German, Russian, any flavor of European tank or mods of them, then Canadian, and at the very bottom the US tanks. Of course revenue ultimately picks most of the tanks so it might take a while.
Well if the company is interested in making different versions of the Sherman than just a 'one off' tank like the Easy Eight M4A3E8 then maybe staying with the base VVSS tank. THIS will yield many more versions than the HVSS will. Although there ARE subtle differences in the VVSS (along with the road wheels), most notably the very first early version used on the M3, you could still get by using a suspension much like the Heng Long company did although I would hope it was a better detailed and well done than what they tried to pull off.
You could NEVER have enough Sherman tanks but also, a need for British tanks from WWII is also much needed and wanted! Churchill, Comet, Cromwell... I could go on and one but won't. So if you are looking for something that WILL SELL, British tanks from WWII are in much need than just rehashing the same German tanks that everyone else has.
Just My Opinion!
Jeff
#33
AB, CANADA
Just My Opinion!
Jeff
Just My Opinion!
Jeff
One I share.
#35
YHR ~ Thanks Dan!
Strato50 ~ I'm right with you buddy! A Grant or a Lee and I would want BOTH!
Jeff
Jeff
#37
Just My Opinion!
Jeff
Just My Opinion!
Jeff
#38
#39
As Tom said, its the sponsons. I've put a brace across it but it doesn't entirely solve the problem. Don't get me wrong, I'm fairly happy with my Taigan Tiger but where the two hull assemblies meet is the weak point both visually and structurally.
#40
ON, CANADA
At least on my Tiger which is essentially a Taigen (Asiatam hull with HL upper) the problem is that the unused posts that used to be used for hull screws don't seat perfectly, thus the upper & lower don't "click" together and you get a gap below the sponsons.
#41
I think Taigen shortens those posts to avoid that problem. Erik would know. I use those braces on all my tanks and they do help quite a bit. I wouldn't mind seeing those offered for sale, along with motor mounting plates. You could probably make your own mounting plate with the cover from an electrical box, but it's nice having the predrilled and tapped holes. You don't use them all, but they're good for alignment as well as fastening to the ones that do fit.
#42
#43
This is the retrofit on my plastic T1. I measure between the front plate where it's metal and carry that size all the way back, using the bar clamp to draw the sides together before I mark and drill the holes. Another brace in the center helps even more, but I haven't put that one in yet. That will be one of the last things I do so I'm not taking it on and off more than I have to. I'm keeping a build log on the plastic T1, so maybe later I'll do a separate thread on that. And once again, with a decent coupon those cheap calipers are $9.99 at harbor freight, they really come in handy and they're plenty accurate enough for what we do here.
#44
Ok so the final answer is yes we do have a Sherman
I feel bad about leading you guys on, but we do stand by our rules of never announcing until production has officially started. I would of never heard the end of it if something happened before we started and I announced it.
