Turret roller bearings
AB, CANADA
I never mentioned this in the Cromwell thread, and this mod isn't tank specific.
I used 6mm airsoft pellets for roller bearings on the Cromwell turret. Those that have the HL Leo might appreciate this mod.
AB, CANADA
I drilled through the hull. I then glued a backing behind the holes, and the drilled a smaller diameter than the 6mm pellets through that. The ball just sits in place.
After this picture was taken I end up doing the same thing on the topside, so when you turn it over they don't fall out.
