Rocker switch
Rocker switch
I'd like to replace my standard sliding HL switch in my PzIV build with a rocker switch. I was hoping to get small ones to save space. I found these on Amazon: http://www.amazon.com/10pcs-black-mi...+rocker+switch. Do you think they'll work? Is amperage rating high enough? If not, what should it be?
TIA
TIA
6A is a bit small, but should be ok. I'm trying to remember how AC->DC switches go, I think it is something like 25% of the rated AC voltage for DC use (I am probably wrong here) and you are ok. Since you are running way below 62V, it should be fine.
