Leopard 2A6 fromHenglong/Matomart
I am a brand new owner of an R/C tank. having problems with main gun elevation. It initially worked fine, now does not respond to the controller. Any suggestions?
Welcome to the world of Heng Long tank maintenance. You may have a wire come loose that drives the elevation. You are going to need to 'pop the hood' and have a look inside and see if you can find a loose wire floating around that connects to the elevation motor. May be something obvious like this. Goodluck.
CaptB
CaptB
