Tamiya m50 sherman
Old 02-05-2015, 02:09 PM
tomhugill
Default Tamiya m50 sherman
Thanks to a kind member of this forum I now have a gutted tamiya Sherman. I'm shortly ordering a 47degree small hatch resin hull off nick Aguilar and then I'll be ready to rock and roll.
This is the aspiration:
This will be running parallel to a couple of other post war shermans
Old 02-05-2015, 02:10 PM
tomhugill
Many thanks to woz who's wonderful parts turned up today!
I've decided to try and get the turret built so I'm ahead when the nick Aguilar hulls arrive. On this I'm using the Tamiya turret but as woz has built the parts for henglong I might get one of these as the conversion will be easier.
Anyway. I've added the bustle extension, built up the mantlet and got it pivoting for the elevation. I've also started soldering up periscope guard, added a split hatch and added the filler to blend the turret bits together.
tomhugill
Some more done today! Still waiting for my hills.
Old 02-05-2015, 02:11 PM
tomhugill
More progress, I've finished the servo recoil and elevation and fitted a tbu. Its quite a tight fit in the turret but got everything in. I had to cut back the barrel as it turned out when it was elevated it hit the back of the turret ring!
Woz has very kindly printed me some smoke launchers so they will be going on soon too.
Old 02-05-2015, 02:44 PM
Captain Nemo12
Captain Nemo12's Avatar
Awesome start! What glue did you use to attach the 3D printed parts?
Old 02-05-2015, 02:59 PM
tomhugill
Just standard CA, they're have a slightly rough surface which I think helps!
Old 02-18-2015, 12:20 AM
tomhugill
Some more progress, added some detail to the turret and started giving the rest of the hill the Mr surfacer treatment.
Oh I've also had my nick Aguilar stuff through so I've added a resin early welded hull with resin transmission cover.
Today's work:
Old 02-18-2015, 04:10 AM
trackmech81
I like it. Cannot wait to see the end result.
1. Is that the printed engine deck and what do you think of it?
2. Do you have an extra transmission cover you might sell?
Old 02-18-2015, 04:22 AM
tomhugill
Hey, yes it is printed. The only downside is the texture the printing gives, sort of woven pattern. I've lightly sanded and then given serveral coats of Mr surfacer. Hopefully when painted the texture will be gone! Details decent although I might replace the bolt detail. All the covers are spoken for I'm afraid. However I'm sure nick could make you some.
Old 02-18-2015, 08:49 AM
RichJohnson
RichJohnson's Avatar
What engine is supposed to be under that engine deck? Is it a war time engine or a post war change out?
Old 02-18-2015, 08:50 AM
tomhugill
It's a post war cummins diesel.
Old 02-19-2015, 01:33 PM
tomhugill
Cheers green, an Egyptian sherman with the AMX turret would be pretty cool!
Some more progress with evening, done the gun travel lock, all functional. The brush guards and started to add stowage bins.
Old 02-19-2015, 01:57 PM
LosTxSouL94
LosTxSouL94's Avatar
I know it's a bit late, but you should look at acetone vaporing 3D printed parts. It essentially 'melts' the lines together to make it smooth. It's obviously dangerous if done wrong, but there are tutorials on Youtube on how to do it safely.
Old 02-25-2015, 05:32 AM
tomhugill
Some more progress on the m50. Built up the Jerry can holder, added some pe mesh. Also finished the side stowage, and added some of the sherman detail sprue bits and all the lighting.
Old 02-25-2015, 06:25 AM
edoubleaz
edoubleaz's Avatar
I have just enough spare parts in my stash for an M-50, hmmm, maybe even the Chilean M-60 with Hyper Velocity Gun..... Decisions...Decisions....
Old 02-25-2015, 07:16 AM
Rex Ross
[QUOTE=edoubleaz;11990530]I have just enough spare parts in my stash for an M-50, hmmm, maybe even the Chilean M-60 with Hyper Velocity Gun..... Decisions...Decisions....[/Q
I vote for the Chilean M-60.
rex
Old 04-05-2015, 04:38 AM
tomhugill
Finally managed to pull my finger out and get some more done on this, been gathering parts to finish it (new periscope guards and oils for the bogies). Something that was greatly lackzing was the big whip antenna IDF tanks seem to employ. Made some out of a thin spring and the Tamiya part off the e sprue.
I'm still not 100% happy with the cupola so may replace with the Mato metal one, or build up another I got from Woz.
Old 04-05-2015, 05:49 AM
Rex Ross
Your project is very impressive --- the work you have put into the turret is especially interesting, but the entire project gets a big WOW from me!!!!!!!
rex
Old 04-27-2015, 11:51 AM
tomhugill
Well I'm try to pull my finger out to get this project moving. I was never happy with the inaccurate turret bustle, it was straight where it should be rounded. Other things done are adding periscope guards, I've rebuilt the hatch so the periscope spins now. I've added the schumo oilers too. I've also done some work on the muzzle break and added some
welds.
Old 04-27-2015, 12:12 PM
Rex Ross
WOW !! A treat for the eyes.
rex
Old 04-28-2015, 04:37 AM
HAL_HUSKER
HAL_HUSKER's Avatar
Fantastic work!!!
Old 04-28-2015, 04:45 AM
mordock999
VERY Impressive!!!!
Old 04-28-2015, 05:30 AM
MAUS45
MAUS45's Avatar
Tom, were the storage boxes 3D prints as well? Also is the engine deck the same for the M50 and M51?
Thanks, Rudy
Old 04-28-2015, 06:18 AM
edoubleaz
edoubleaz's Avatar
There were a few styles of the engine decks. There is a drawing of M51 Decks that I'm told mirrors the development.
Name:	Engine Decks.jpeg
Old 04-28-2015, 06:21 AM
edoubleaz
edoubleaz's Avatar
The mantlet is for sale on Shapeways.... Just ordered. I got my Muzzle brake yesterday.
