HL King Tiger throwing tracks
Hey Tankers , I have been having issues with my tiger wanting to throw it's tracks when I turn on anything but hard surfaces. I have looked over all I can and need some advice on what I can do. It appears as I turn , the teeth of the track want to creep out of the rear idler and of course there is no slack adjustment on those Heng Long units.
Eventually you will need to pick up a rear idler adjuster from Erik @ Imex. for a quick fix try adding pieces of plastic/styrien under the rear fender above the rear idler just enough so that the guide horns cant lift out and off the idler,thus you will be able to tinker with her until the rear idler can be replaced with one that can be adjusted.
Hello,
look at this.......http://www.rc-panzerketten-forum.eu/...threadid=30888
maybe it can help you.
regards,Guido
regards,Guido
