My M51 attempt.
I would suggest get some sticky weights like the kind used on tire rims or model trains and put them on the rear most spot on the bottom of the reocil mount to help balance the gun out. The long barrel is rough on the elevation box. One or two would be enough.
Thanks for the tip Rich. I will a that to the todo list. I am waiting for the last couple parts to get here from Oddball, he does great work, and an antenna from DKLM with the spring built in.
