fitting an mg to a tiger.
If I fitted a led mg into the turret of a Taigen Tiger 1 where on a T22 CLARK board would I plug it? shaun
Thanks Joe, That is pretty much what I thought.
It is just that if you design a control board for a Tank MG (most makes and types of which have TWO MGs) why fit only one socket?
I would expect CLARK to say they were limited by space, but they have two sockets for the smoker ( one for the switch and one for the smoker) whereas the IBU2 uses just one socket for the smoker!!
shaun
shaun
I think Clark addresses this issue in the TK60. The Asp is set up for Machine gun 1 and 2 and each has it's own fire switch.
I added the turret MG for that tank I just did for a guy at work, and all I did was just as Joe said, tie right in to the existing MG. Works just fine. But remember that with the clark board and turret MG the Taigen airsoft w/mg slip ring kit won't work, you'll have to get the IR slip ring, and that won't be plug and play for airsoft. To get it just right with a clark and a turret MG you need an 8 wire slip ring.
