Pinion Gears *sigh*
ON, CANADA
Pinion Gears *sigh*
Hey all,
Here we go again... I'm looking for stock replacement Heng Long motor pinion gears.
I get conflicting info everywhere. Yes I've searched the crap out of RCU and Google and every other tank forum. The best I come up with is "Hey, try this, maybe..." and 1/2 of what I find are dead retail links.
So... anyone who ACTUALLY knows I'd love to hear it.. is HL using 48 pitch, 0.5MOD, 0.6Mod... or what?
Where can I get a whack of them? They're tiny pinions and should be 50c each, not $5-6.
...heck I'd be happy with plastic gears, not much torque coming off the motor!
I might be able to help. I've got a buttload of pinions you can have but you'll have to pay the postage. I'll take one to work and give it to the eggheads and see if they can get the pitch for you. I have two different kinds here, brass and steel, any preference?
36 pitch Edit:48 pitch
http://mitosal.com/HopUpGear.htm
Thought ETOarmor carried some as well but couldn't find any on their site.
Thanks, Bret, for the pitch, because I forgot to bring one in this morning.
So Strato, if you just want the stock HL pinions that come on the motors I have a bunch of them you can have, Just let me know if you want the steel or brass pinions. Or both.
48p for the gears. I used 48p gears direct from my 1/10th scale SCT and it fit perfect. The brass gears are a bit different though. I believe they are .6 mod. I don't have any more left around to see
Does it matter if they're the smaller pinions from the motors or the ones from the dual ratio with the set screw? The steel DRGB pinions with set screw and snout are 48 pitch, but the brass are .6 mod. I'm still not positive about the tiny (8 tooth?) pinions that come with the stamped steel-sided GBs.
ON, CANADA
Oh see the fun I stir up? :P
I do mean the little 8 or 10 tooth pinions on stock HL gearboxes. Don't know anything about set screw gears but that'd be nice, beats destroying motors trying to get these damned press fit gears off...
ON, CANADA
One day I'll find a puller that works... I've bent a couple before giving up without even budging the darned pinion.
This one seems meaty though.
http://www.amazon.ca/gp/product/B003...ilpage_o00_s00
I've used the GWS GP-Std for over 20 years with no problems. Yup some pinions are tough, but even cranking hard as hell this one has never failed me.
http://www.gws.com.tw/english/product/other/gp.htm
Was just looking for a link for you to possibly buy and check out but looks like they are discontinued. The one your looking at looks pretty good though.
I came up with two pairs of brass pinions for you, and two pairs of steel as well. I have more steel pinions if these aren't enough. Now I have to figure out how to send it like a letter. Otherwise the shipping will be a killer. I'll do my best to get them in the mail this week, but to be honest it will probably be more like Monday.
I just ordered a pinion puller myself.
Will makes things a ton easier!
http://www.ebay.com/itm/Universal-Pi...item2c67580c67
disappeared unfortunately. I have seen them on ebay occasionally. Solid brass without the use of the sliding piece that looks to give resistance on the pinion that the walkera has. I"m guessing that may be what Strato has bent on his.
Damn, guess I better remember to be running a heavy for that! And what if it's the best small gadget in your toolbox? Guessing you'll be fine, according to Shaker and Chief it's a good puller.
