Centurion Tank 1:16
Old 04-01-2016, 03:49 AM
  #101
Panther F
Panther F's Avatar
Geez... so tempting.
Just wished I didn't have so many other things to build FIRST! Maybe an RTR but the time and devotion into a HUGE build like this would be so consuming. But worth it.
Jeff
Old 04-02-2016, 03:59 AM
  #102
chris3BK
hi
i m happy you like it guys :-).
metalroadweels should be no big problem, but would be relativ expensive and the delivery time would be about 8 weeks i think.
cu christian
Old 04-02-2016, 01:18 PM
  #103
Strathcona
I served on Centurions back in the "70's in Germany. The Centurion is my favorite tank.
Old 04-03-2016, 03:26 AM
  #104
Panther F
Panther F's Avatar
I bet you have a HUGE photo album. You should post some pics of your time on them someday!
Jeff
Old 04-14-2016, 10:24 AM
  #105
Longsheep
Chris's Centurion is almost available! Just heard from him.
Old 04-16-2016, 10:51 AM
  #106
chris3BK
hi
almost but not complet, i m still waiting for these dam longer axis for modivying the gearboxes :-/.
cu christian
Old 05-06-2016, 10:23 PM
  #107
Longsheep
To everyone interested in the Ludwig Centurion - Clark Model has the recordings ready for the Centurion.
A TK-20 series board (all-in-one functions + sound) can directly replace HL board and also use Tamiya battle system. I have one on my HL Leopard 2A6 and it has been great. Minimum order is 3 identical boards at $95USD each + shipping from TW.
Any taker? I will get one and Chris will likely to get one for himself too. It may takes some time to get that custom board made, so I wish to order in-advance.
Update from Chris confirms that the Centurion is VERY close to completion. He is away for a few weeks on holiday though.
The Chally one sounds something like this: https://www.youtube.com/watch?v=ohhFoqPHdaY
Old 05-07-2016, 04:38 PM
  #108
Lincs Winks Wayne
Lincs Winks Wayne's Avatar
Originally Posted by Lincs Winks Wayne
Chris:
I served numerous years as an Infantry company OC with a troop of Centurians attached and have been interested in a 1/16 or 1/25 RC model since the late 60's and early 70's ( to go with my old Leopard 1 and Chieftan or my current Leopard 2A6M CAN, M-51, M-26, JS-1, T-55, Panther and Tiger-1)
If possible I would appreciate some sort of notification when this beauty is available.
Wayne
Chris:
What is the status of this kit ?
ETA
What is included
Cost
Shipping to Canada
Any info would be appreciated.
Thank You
Wayne
Old 06-06-2016, 10:27 AM
  #109
Longsheep
Hey guys,
I can confirm that the Centurion is already completed and available to order. I ordered all essential parts last week for about 850EUR and the kit should ship in 3 weeks. Details here:
http://www.ludwigs-hobby-seite.de/Centurion%20MK%20III%20Tank.html
I have also talked to Clark (Clark Electric of Taiwan) to make a TK24 board for Centurion, which he already has the sound recording. Minimum order is 3 pieces, I will take one and Chris will take the rest.
There are only 2 production components needed: the Elefant tracks (Asiatam) and the metal HengLong PZIII suspension arms; which will be used inside the Horstmann boogies and not normally seen. Almost everything else are CNC plastic. The 20pdr Type "A" will be hand-milled in AL. Pretty impressive just by looking at the instructions pdf:http://www.ludwigs-hobby-seite.de/Ce...uanleitung.pdf
I am going to run it at scale speed so the stock hull should be fine as-is. Chris can make certain parts in metal instead of plastic but he insisted that thick plastic hull would be stiffer than even Tamiya metal ones. So I went with all-plastic.
This is probably the first 1/16 RC tank with Horstmann suspension system!
Old 07-02-2016, 09:16 AM
  #110
Longsheep
Started building mine!
Just found out the "Panzer III return roller mount" is not included in the set, have to order 2 packs of MATO MT025 ASAP.
ID:	2170885   Click image for larger version
Old 07-03-2016, 02:37 AM
  #111
Ad Lav
Looks great! Will keep an eye on your progress!
Old 07-04-2016, 05:48 AM
  #112
chris3BK
hi
i m happy to see you have started the build :-).
i m sorry, i need to put the returnrolers on the list.
cu christian
Old 07-04-2016, 08:44 AM
  #113
Longsheep
Originally Posted by chris3BK
hi
cu christian
Hi Chris, we need 8 rollers per tank and so I have to order 2 packs as each pack only has 6 rollers.
I think you can order more packs and mix them, so 4 packs of MT025 (6*4 = 24) can fit 3 tanks!
Old 07-04-2016, 11:19 AM
  #114
chris3BK
hi
yes, please send me a mail and i will send you some ;-).
cu christian
Old 07-04-2016, 06:14 PM
  #115
Longsheep
hi
cu christian
Chris, I have ordered the rollers locally as we have Mato dealers in Hong Kong, but I think other owners will appreciate your help if you list them on your site.
Old 07-07-2016, 07:05 AM
  #116
chris3BK
hi
ok, i have add it to the list now.
cu christian
Old 07-07-2016, 07:21 PM
  #117
afv aficionado
Hi Chris
Just realised that there appears to be no side skirts?
Mal
Old 07-07-2016, 07:34 PM
  #118
Longsheep
Originally Posted by afv aficionado
Hi Chris
Mal
It is included in my kit, including small detail parts on the skirt.
Old 07-07-2016, 07:39 PM
  #119
afv aficionado
Hi Longsheep
Cool, couldn't see them on the website. My hull is apparently on the way, though taking a while to clear the starting blocks...
Mal
Old 07-07-2016, 09:09 PM
  #120
Longsheep
The upper hull is finely designed and milled - it snaps-on tightly on the lower hull to provide extra hull stiffness and strength. The deck can be removed without any tool.
You have to glue/weld the styrene seamlessly to get maximum strength.
If done properly, the seam should be as strong as the rest of the sheet. I add epoxy inside the load-bearing seams (like the lower hull) just to be sure.
A little help from dozer Centurion to press down the seams...
Then I proceed to clean up the 3D printed final drives. Tried some new tools I bought in Tokyo last month.
I cut off injection marks with a Volks 9mm shaping knife. It is marketed as made of folded and heat-treated steel, just like a katana. Very sharp and hard. Cuts even thick plastic with a light push (about $35USD).
I used my Japanese Hiroshima Wataoka for-plastic file (Nigata Yasuri) for this task. It removes material extremely fast, although it is quite expensive for a file (about $15USD). I think you can order them on 1999 store.
The printed plastic is to my surprise, styrene (not ABS) and can be glued with regular Tamiya hobby glue.
ID:	2171858   Click image for larger version
ID:	2171859   Click image for larger version
ID:	2171860   Click image for larger version
ID:	2171861   Click image for larger version
Old 07-08-2016, 02:24 AM
  #121
Panzerjaeger66
Mal,
if you have access to HLPF, you'll find my detailed report (only in German ) from building the first prototyp, additionally to the instructions at Chris homepage:
http://www.heng-long-panzerforum.com...threadID=18698
Freddy
Old 07-08-2016, 05:53 AM
  #122
Jhdumas
Another Great Tank Christian!... When is an M-10 coming? Joe : )
Old 07-08-2016, 06:07 AM
  #123
Jhdumas
Jeeze CHRISTAN... Another great Tank... I know many have been requesting a Centurion for some time now..... Your Churchill is actually my next target.. I'm psyching-myself up for that build and it seems like a fairly complicated build... it may be above my paygrade...
I finally got (with your Help) the FAMO from Asistam....Thank You..... I still have your Cromwell to do.... so many tanks, no time... for what it's worth.. I vote for an M-10 or an M-18.... : )
Old 07-11-2016, 07:18 AM
  #124
Longsheep
It is starting to look like a Centurion with the side attached. The top end of the upper front plate needed some filing to become horizontal.
I plan to hold the engine hatch with strong magnets. The whole upper deck is still removable with bare hands.
The return rollers mount set is not included in the kit. MATO MT025 is recommended but the axle is too short.
There isn't a "correct" way to get it done. You can mill M3 threads inside a M5 set screw but I do not have the equipment. Instead I got some 15mm screw extenders to get it fit. Some drilling on hull side is required.
ID:	2172389   Click image for larger version
ID:	2172390   Click image for larger version
ID:	2172391   Click image for larger version
Old 07-14-2016, 02:41 PM
  #125
afv aficionado
My Cent hull turned up yesterday - 5 kgs of plastic, plus a couple of metal bits. Bit of a dilemma, start this, or continue with the Scorpion?
Hi Freddy, thanks for the link, but couldn't access the site.
Any further progress Longsheep?
Mal
