Tamiya Pershing Road Wheels
New to me, used Tamiya Pershing. The road wheels seem very sloppy (wobble) is this normal? How tight is the tolerence on the shaft to bushings on these? Is there a standard bearing replacement kit for them or just replace with OEM bushing and shafts. I would assume that if the bushings are worn, the shafts will be also. I was just going to clean and relube bushings and shafts with Super Lube. Thanks for the help, its my first Tamiya.
Well... bushings CAN wear out and bearings are much better than what is stock in the kit BUT, if a petroleum based lubed was used on those wheels they are prone to cracking and this can cause a wobble condition.
So, without looking at at them I'd say take them apart and inspect before ordering the flanged bearings. I installed these right when I built mine and they are very stable.
Jeff
And I should have mentioned that you will need 5X8MM flanged bearings and 42 of them for the road wheels. AND make sure unless they are advertised as packed with plastic safe grease, wash them thoroughly in alcohol and repack with either ceramic grease or a plastic safe grease.
Hope your wheels or axles were not affected!
Jeff
Jeff
Sent you a PM, axles seem worn also, wheels seem good, no cracks.
Hopefully this will solve the problem.
Jeff
Jeff
P.M. returned and anytime too!
Jeff
Jeff
